Here is a copy and paste from the RHS site....
"Revised combustion chamber design for excellent combustion thermodynamics and enhanced fuel efficiency" Now, I don't know if this means that the chambers are very fast burn like the Chevrolet L31 design and others currently available, but if they are, then you won't need any more than 34 degrees total initial and centrifugal, with more available from vacuum at cruise. One of the best guides to determine the initial ignition timing of V8 engines can be found in the Barry Grant, Inc. catalog or at their website under the Demon Carburetor Guide. Typically, they recommend 10- to 12-degrees of initial timing when the duration of the camshaft is less than 220-degrees @ 0.050” of valve lift; 14- to 16-degrees of initial timing with a camshaft duration of less than 240-degrees @ 0.050”; and 18- to 20-degrees of initial timing when the camshaft duration is less than 260-degrees @ 0.050” of valve lift. So, put the initial where it needs to be for the cam timing, then change your centrifugal advance curve to provide a total of 34, all in by 2800. Then add the vacuum. |
Cam is a Performer RPM (not my choice) and CR is 9.35:1 from what I can gather (why it was built with 64cc heads and -18cc dished pistons, I just don't know). Anyway, timing recommendations? |
Yep, 11AM here. I could never post anything that made sense at 6AM unless I'd had a few strong coffees first! |
I'm sitting here watching CNBC, trying to get a handle on the market for Thursday. Man, oh man, those damned stupid Greeks are back out in the street protesting. What part of "BANKRUPT" do those people not understand?
Here is the spark table for my 383 with AFR 195's and a 219/219 roller cam at 9.9:1.
Not exactly the same combo but thought it could give you and idea of what others are running. This was arrived at from a Vortec base timing curve and then data logging runs, it has not been tested on the dyno yet. One thing that was very clear for this engine was that although it liked alot of advance under light throttle (35), when the load increased, it wanted much less. (as low as 20 deg). I know this info won't be a direct help as you are mech/vac timing and a carb but thought I'd share anyway to give an idea of what's worked for me. |
“The problem with socialism is that you eventually, run out of other people’s money.” - Margaret Thatcher |
They didnt know how good they had it Sorry folks. Now back to your regularily scheduled thread |
| Ignition Timing a Modified V8 | Argess | Engine | 8 | 07-10-2009 04:11 PM |
| Setting timing on 383 (plus a few other questions) | gneitzke | Engine | 5 | 05-27-2009 12:22 PM |
| Ignition timing woes | KNanthrup | Engine | 16 | 07-22-2007 09:18 PM |
| Ignition Timing (again....) | pass-n-gas | Engine | 22 | 06-12-2007 10:47 PM |
| Ignition timing, Jeep 4.0 | ChevelleSS_LS6 | Engine | 0 | 10-26-2006 06:20 PM |
