383 intake/cam questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2009, 08:20 PM
i got a 383 sbc (10:5-1 approx) with a comp cam magnum 292. .501 im wanting to run either a 3x2 intake (preferebly) or a 2x4 intake. the reason is primarily for looks my question is first is this a bad idea? i can live with some power loss for the looks. also does anyone have any ideas on a good 3x2 intake? thanks in advance
Old 07-16-2009, 04:19 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi!
You missed the trip set-up, but here is a dual quad factory piece. Then there's Edelbrock.
Rich
http://www.hotrodders.com/ads/showpr...1&cat=2&page=2
http://www.jegs.com/p/Edelbrock/Edel...46549/10002/-1
Old 07-17-2009, 03:14 AM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
No, it's not necessarily a bad idea. I've built several 2-4 motors just for the looks. Like you, I didn't care whether or not it was the definitive intake system for power as long as it made me smile when I opened the hood.
Old 07-17-2009, 05:40 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The main problem w/a three deuce set-up, IMO, isn't the set-up per se- it's how it's set up.
If the ignition advance curve is dialed in right, the carbs are sized and tuned correctly, choked correctly and have a progressive linkage, there's no reason it can't be every bit as effective- if not more so- as a dual 4-bbl. and can rival even a single 4-bbl. set-up.
A while back, one of the Pontiac mags did a test where they built a BG carb-based tri-power and tested it against a 4-bbl. carb and intake. The trips did fine. For ~$1500 it should have done well!
In your particular case, that cam has the makings for a low vacuum signal to the carbs, so tuning will require the usual procedure to get a good idle to mid transition. But nothing that can't be done in a leisurely afternoon.
383, more questions sgo70 Engine 5 12-27-2007 12:55 PM
Starting on first engine soon, lots of questions OneBeast Engine 6 09-12-2007 07:27 PM
383 questions!!! 400smb_s10 Engine 12 08-13-2007 07:26 AM
How much HP on my new 383 engine, plus some questions for the pros! Ken-96GMC K1500 SC Engine 8 05-13-2004 02:07 PM
Questions, questions, questions? slider in wa Transmission - Rearend 2 09-27-2003 02:01 PM
