383 kits - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2013, 06:59 PM
383 kits
hello friends. I would like to pick your brains on the best and cheapest way to build a 383 chevy engine. I need it to rev about 7,500 rpms and live?? any help would be helpful thanks
Old 10-26-2013, 07:30 PM
silence should tell you something . Oh , and also , best and cheapest are 2 opposites !!
Old 10-26-2013, 08:20 PM
jokerZ71's Avatar
Wrench Turner
Skip White sells a nice kit for $873. Scat crank & rods,Probe forged dish,or,flat top pistons.Decent balancer & flex plate.King Bearings,Hastings rings.All good parts.BEWARE OF EBAY KITS !!!
Old 10-26-2013, 08:50 PM
techinspector1's Avatar
Wiki Edits: 326
What is the application where you need 7500 rpm's?
Old 10-26-2013, 09:33 PM
jokerZ71's Avatar
Wrench Turner
383's are not the best choice for a high RPM engine.
Old 10-26-2013, 09:38 PM
vinniekq2's Avatar
your 7500 RPM will be mostly limited by the cam and gear you use with it.
I would use a good crank,callies/crower etc. though there are cheaper cranks that will also work. Likely talking an engine in the $8,000 range with good parts. for what it costs when you make this type of power,spend $1800 more and get a Dart little "M" block and build a 434.
Old 10-26-2013, 10:00 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
Howards make a pretty good crank for the buck:
383 Stroker Kits tools Hotrodding Basics 3 09-04-2013 11:05 PM
383 build kits? Camaro R/S LT Hotrodding Basics 38 01-09-2013 03:53 PM
383 Stroker Kits kburb Hotrodding Basics 2 12-03-2011 06:44 PM
383 stroker kits?? for a 98 block kennyhammond Engine 7 01-18-2011 02:08 PM
383 Stroker Kits Chevy21 Engine 11 12-02-2004 10:38 AM
