Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 383 low vacuum and idle issues
Old 08-30-2012, 04:36 AM
454C10 454C10 is offline
Buy an adjustable vacuum advance canister and set it to 10 degrees then use manifold vacuum.
Idle the engine a little higher.
With the engine warm, you still should adjust the idle mixture screws to get the highest idle.
