Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 383 low vacuum and idle issues
Old 08-31-2012, 07:37 AM
Custom10's Avatar
Custom10 Custom10 is offline
my KARMA ran over my DOGMA
Last journal entry: SS
Originally Posted by oldchevy1956 View Post
Again thanks for all the advice as, even though I have been setting timing and such for a long time on cars, I was struggling with this particular engine for some reason.
A good excercise would be to check for true TDC and set the pointer on the damper. Make sure that the timing pointer lines up with the 0 mark on the damper when #1 piston is at true TDC. Use a piston stop.
It could be that you are off on the mark (slipped damper outer ring, wrong pointer, inaccurate pointer etc.) thus the timing is actaully less/more than you are reading with the light. This procedure is well worth the effort.
http://www.crankshaftcoalition.com/w...op_dead_center
