383 Machining Costs ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-03-2002, 03:34 PM
Talking 383 Machining Costs ?
I have a 355 CI Chevy SB with 4 Bolt mains. Over the winter I was going to have the block Magnafluxed, new freeze plugs and cam bearings installed which will cost about $250. How much did it cost you gentlemen to have the block machined for the 383 Stroker crank ? Thanks for the help.
Joe
Old 10-03-2002, 04:33 PM
Post
I had machine work done on a 350 bored .030, balabced, crank polished, pistons, gasket set, bearings, rings, brass freeze plugs came to $800.00. Balncing was $200.00.
Old 10-03-2002, 04:35 PM
NAIRB's Avatar
Post
Man, that's alot of dough just to mag, clean and cam bearings. Clearancing the engine for 3.75 stroke shouldn't cost that much. Anyway, you can do it yourself with a carbide bit and a die grinder. 250.00 whew!!!!
Old 10-03-2002, 05:54 PM
Post
i got all my machine work for 500 including the cam bearing and freeze plugs <img src="graemlins/pimp.gif" border="0" alt="[pimp]" />
Old 10-04-2002, 03:09 PM
Talking
Thanks for the help !!
