383 mopar questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-16-2001, 08:07 AM
New Member
Post 383 mopar questions
How hot do these engines run? I been told that that run as hot as 220 degrees. Is that true?
NICK,
Old 12-16-2001, 08:50 AM
Post
220 is plenty warm and I would like to see more like 190-200 max,try a cooler thermostat,whats the coolant look like,if its rusty looking time to flush and change it,Ive also seen radiators plugged with bugs and crud so bad air couldn't get through. Just some things to try if you haven't already.
Old 01-15-2002, 08:21 PM
Post
check your bottom radator hose. common problem on bb mopars. they can collapse and restrict flow down to 1/3. to fix this, just make a spring shape support out of coat hanger and put it inside the hose. this will add support so the hose wont kink.
hope i helped,
dave
ps make sure the spring fits tight in the hose.
Old 01-22-2002, 09:30 AM
1meancuda's Avatar
At a loss for words
Post
I've never used it, but I wonder if something like Redline's Wetter Water would help.
