383 nead help - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-06-2010, 08:16 PM
383 nead help
Did i grind to much, it took alot to get .065 clearance. cam is a 266 @50 solid roller 640 lift 112 lobe sep. Do i nead to get som stroker rods? The crank is a 400 turned down. Thanks for help
ID:	47924   Click image for larger version
Old 09-06-2010, 08:27 PM
ericnova72's Avatar
More for Less Racer
.040" clearance would have been more than enough, if the crank can flex more than that its gonna blow apart doing it. You shouldn't have needed to go that far down the side of the rod either. I'd be a little leary of the amount you removed from the bolt head. Are these ARP bolts?? ARP is the only brand I would even think to trust with that much removed, and those don't look like ARP in the pic. If they are stock...no way would I use them.
If you use a .040" thick 12" long plastic zip tie as a feeler gauge it is easy to tell if it clears or pinches between the rods and cam lobes. Another tip is to measure from the rod bearing bore out to the angled flat you ground on the rod and grind it to a .625" thickness measurement directly tangent to the rod bore, this will clear 98% of all cams you might use
Old 09-06-2010, 08:31 PM
ericnova72's Avatar
More for Less Racer
Also, ground as far as you have, I have seen them start to split the head off the bolt, and have seen the rod material start to collapse under the bolt head due to lack of material. Neither situation is good for torque value retention.
Old 09-06-2010, 09:03 PM
Thanks for the reply, those are brand new arp rod bolts, also the guy that had the motor before me ground all that far down on the rod, the rod bolts are the ones that have a angeled head for clearance. I just kinda matched what was done previous but it looks kind of scary to me. Im wondering if thats the reason it turned two bearings on him? I had rods resized and new bolts put in, i think i just wasted my money.
Old 09-06-2010, 09:11 PM
ericnova72's Avatar
More for Less Racer
If it spun two before, you could make a reasonable assumption that the rod bolt torque may have relaxed, causing it to spin. They don't spin for just no reason, either tension relaxed by some means(bolt or rod material), or lack of oil, or rod bore out of round(could be bolt problems there too).
$200 SCAT rods would be a good deal, I couldn't make myself use what you have, it looks like too big a risk, could end up real expensive if they fail.
Old 09-07-2010, 07:32 PM
Thanks for advice ive decided to get some good rods too much invested to go cheap where it counts.
Old 09-20-2010, 08:44 PM
Guys heres a update i got my new rods and went with a new set of speed pro hypers and new ring set. The issue with the rings is i put them in the cylinder to check ring gap and it .120 what the heck? My old wore out rings are only .030 gap. did they send me the wrong rings im confused if i put that together it would have way to much blow by correct? please help guys thanks. Its a standard bore and standard pistons.
Old 09-20-2010, 08:48 PM
techinspector1's Avatar
Wiki Edits: 326
Yeah, wrong rings. Don't use 'em. What is the part number on the packaging. Have you checked to see if that number coincides with your motor at standard bore?
Old 09-20-2010, 08:59 PM
ericnova72's Avatar
More for Less Racer
I have run across recent posts on other boards about rings packaging foul-ups from Speed-Pro/Sealed Power like you describe. Speculation was it has something to do with many of there parts being made in India and Mexico, but I don't know if anyone posted where the rings are being made to confirm this.
You definately have a problem with a .120" gap, miss-marked packaging or incorrect rings in the correctly marked boxes. You're going to have to get in touch with customer service where you got the parts.
Old 09-20-2010, 09:03 PM
The part number on the box shows to be correct could they have put wrong rings in the box? The part# E251K , 2M139. What do i do now reorder the correct ones for standard size pistons? this sucks. what do you guys prefer for rings and should i get the file fit rings, there hyperutectic speed pros
Old 09-20-2010, 09:12 PM
Wiki Edits: 326
Opinions may differ on this, but I would only fool with file-fit rings if I were blueprinting and assembling a race motor. There is so much wrong with a run-of-the-mill street motor that precision ring end gap would be the last thing I would worry about.
I don't think Speed-Pro uses a strange top ring end gap like Keith Black does, so I would just use whatever the rings end up at, like somewhere between 0.018" and 0.022" for instance on a 4" bore. Make sure you follow their instructions though, in case they are different from what I have just said. Too much gap is way better than too little gap.
Just call up the guys where you ordered them and get their instructions for returning the bogus rings and getting the genuine articles. One point I will make, be certain that you check EVERY ring for backspace and vertical clearance in the ring grooves and ring end gap in the bore.
Old 09-20-2010, 09:17 PM
Thanks for your help.
Old 09-20-2010, 09:24 PM
ericnova72's Avatar
More for Less Racer
Sure sounds like wrong rings in a correctly marked box, that part # is for 4.0" bore rings, 5/64", 5/64", 3/16" (stock)ring widths. Appears you may have 283/307 rings in the wrong box if they match this on widths but you have a .120" gap.
I wouldn't fool with file fits in your case either, not enough gain for the hassle involved, plus you need a ring filer.
Like Techinspector said, if recommended gap is .018-.022", a larger gap in the upper .020's on the top ring won't hurt a thing, but .120" is certainly way too much.
For stockish and claimer level rings, I like Hastings and Grant.
Old 09-20-2010, 09:31 PM
Thanks guys im sure glad i checked the ring gap can you imagine how much blow by that thing would have? Would it even run rite i wonder how many people have just throne something together without checking that sort of detail.
Old 09-20-2010, 09:38 PM
Wiki Edits: 326
According to some of the questions I see on forums, I would suspect most of them.
Ok, here's the debate of the century: 383 or 400 chevy!! Cast your vote and reason killerformula Engine 303 03-28-2013 08:08 PM
383 stroker v.s. 383 chrysler ...the end mcharger440 Engine 58 12-07-2012 08:16 AM
350 vs 383 build for performance Biscuit6447 Hotrodding Basics 20 03-05-2010 08:42 AM
383 0r 406??? Zubair Engine 60 10-14-2005 07:53 PM
What makes a 383 so much more expensive? Chevy21 Engine 12 09-30-2004 08:55 PM
