383 piston question - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-12-2007, 05:49 AM
383 piston question
I was in the process of building a 355 with speed-pro hyper. high dome pistons. I believe they are .75 domes around 12.5-1 compression. Of course using 5.7" rods.......Aracer friend of mine told me i ought to put a 400 crank in with my domes for a 383. I was a little nervouse about the domes hitting. He said to use the 400 rods(5.5" rods). This engine is going to turn around 6,500 on a dirt track. I am also a little nervous about running short rods. I know this sounds like a torque monster for the street maybe, but i don't know about 6,500 rpms. Any ideas on this?....what about running my domes with 5.7" rods?.......Do i just go thru the mock build-up with clay and see wear the valves are?(with 5.7")......
Old 11-12-2007, 05:57 AM
RippinRon's Avatar
You could use those pistons with the 5.565" 400 rods but would have to deck the block to maintain a good quench. I wouldn't spin a stock short rodded 383 to 6500 rpm though.
piston to valve clearence/quench question babygene41042 Engine 8 07-23-2007 06:24 PM
383 efi spark advance question ASAP 383silverado Engine 4 07-17-2007 01:16 PM
piston selection question malibu68 Engine 6 05-16-2007 11:02 AM
Important Piston Question Please Advise Houman SS '70 Engine 27 05-13-2005 09:42 AM
Question on Piston Ad - Re: Application thenige Engine 3 01-21-2005 02:11 PM
