Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 03-17-2007, 08:29 AM
70bird's Avatar
70bird 70bird is offline
Smile if you know Jesus
Which 383 pistons for 64 CC heads
I recently discovered that I may be needing to rebuild my 350 due to the fact that may cam may have lost a lobe. I'll be checking that today. I am considering building a 383.
The heads I have on the engine currently are 2.02 041 64cc's. Am I going to need some sort of dish top piston to keep the CR and cylinder pressure pump gas friendly?
This is going to be a budget build for my DD.
Also, any cam ideas for a 5000lb Blazer 4x4? I have/had a Comp Xtreme 4x4 cam (210/218 .447/.462, 111*) that may have lost a lobe in less than 7000 miles. I loved the performance of that cam.
Old 03-17-2007, 08:47 AM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
Is There Anybody Out There?
re: Which 383 pistons for 64 CC heads
I would run a D dish piston, likely in the 18cc dish size, this with a close quench distance will give it excellant combustion characteristics. As for a cam I would look at comps line of 4X4 extreme cams, they`re made just for the purpose.
Old 03-17-2007, 12:34 PM
Lil Big Mec Lil Big Mec is offline
GM Tech
Exactly what he said! And you might want to read this thread on oil for cam break in. Could help you save your next camshaft. I would probably go with an Xtreme 4x4 262, the bigger engine will love it.
Old 03-17-2007, 12:47 PM
70bird's Avatar
I have a buddy that has went through 2 Comp XTreme cams now I have (possibly, I need to get off this thing and start working on the truck) gone through one.
Also, I've been told on this board to stay away from the Comp XTreme's b/c the aggressive rams make them more prone to losing lobes.
So, I am skeptic about getting another Comp XTreme cam, even though I loved the way it performed.
Old 03-17-2007, 01:08 PM
GM Tech
I've used them successfuly in 5 engines now. I just did my research first and discovered beforehand the modern oil problem and flat tappet camshafts. I use the Comp Cams assembly lube, pour a whole bottle of GM EOS in the lifter valley, and add another bottle to the oil when I put oil in it. I use the Rotella Diesel oil courtesy of my father who owns a trucking company and still has a good supply of the older stuff and I break my cam in for a minimum of 30 minutes varying the rpms, not just cranking it to 3000rpm and leaving it there. And I keep a garden hose handy to spray the rad to keep it cool Immediately after cam break in I change the oil and filter with Rotella and add a 3rd can of EOS. Run it for 1000 miles and then use Mobile 1 Synthetic oil from then on. 1 383 in a S15 Jimmy has 32000KM on it with nary a problem. I have yet to loose a cam.
Old 03-17-2007, 01:16 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
A Keith Black KB135 piston would work nice (18cc Dcup)
A comp cams DEH265H-10 #12-208-2 will run very very simular to the Comp extreme cam you had and has slightly more conservative opening/closing ramps. (more reliable)
A Crane cams #113931 Grind Number: H-266-2 (REPLACES HMV-266-2) is a good simular replacement also.
These cams were designed with more bias towards reliability than the extreme series, while still delivering the goods.
For a 383ci motor you may/or may not want to stepup 1 cam size to a
Crane Part Number: 113941 Grind Number: H-272-2 (REPLACES HMV-272-2)
Another proven great cam
Either case some moderate cylinder head porting will really wake up those good GM 041 heads. A 1.6:1 intake rocker arm is nice too.
Not all the 64cc heads are actually 64cc. Can range up to 68cc. The only way to tell is to cc yours.
I would get used to adding a bottle of GM EOS to every oil change for a long flat tappet cam life with todays reformulated oils. You could probabily split a big bottle over two oil changes after inital break in. 1/2 a $7 bottle should give the nessessary cam lobe protection while only adding minimuly to the cost of oil.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Which 383 pistons for 64 CC heads"
Pro 235 cc heads for 383 SBC flyin99 Engine 1 03-01-2007 07:11 PM
What heads for a Gen 2 383? mattson70 Engine 0 02-28-2007 11:12 AM
Anybody make dome pistons to work with Vortec heads? dirtracerx Engine 3 09-09-2006 09:05 AM
383 with 64 cc heads, can it be done 70bird Engine 7 12-17-2005 09:19 PM
What is the Best cam for a 383 Strker with Domed Pistons 67' BoleroCam Engine 4 12-05-2002 02:37 PM
