383 on pump gas - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-15-2013, 10:09 PM
I want to get the compression down. What about getting a little from everywhere. Run a couple thou thinker gasket, polish the chambers and pick up a cc or 2 and enlarge the valve reliefs slightly (I've heard of people doing this. Not sure if its a good idea)
  #17 (permalink)
Old 01-16-2013, 06:18 AM
Greg T's Avatar
www.krusinklassics.net
You can do all that if you like and won't change much. I would just install a water injector and call it a day. If the motor is not built yet, change pistons.
If you do not want to register, fill this field only and the name will be used as user name for your post.
how to run 383 stroker on pump gas 383elky Engine 42 08-23-2011 01:21 PM
Pump Gas Versus Race Gas / dyno results ?? fastlaners Engine 8 04-30-2011 10:51 PM
Is it normal to have to pump the gas several times to get accelerator pump squirt ? fumplet Engine 3 11-16-2010 01:14 PM
mixes marine gas and regular pump gas crussell85 Engine 3 08-20-2010 08:19 PM
mixes marine gas and regular pump gas crussell85 Engine 4 08-19-2010 06:30 AM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
