383 on pump gas - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2013, 11:48 PM
383 on pump gas
Hey guys
Me and my brother are building a 66 acadian. We just picked up a sbc 383 from a freind of a friend. The guy we bought it from didnt know alot about it so i pulled the heads of to check piston to deck height and do a little clean up on the heads. Im wondering if we are going to be able to run this thing on 91 octane. Im getting 10.95:1 with a dynamic of 8.43:1
SBC 350 40 over
Scat 3.75 crank
speed pro flat tops (5cc)
Felpro head gasket 4.166 bore/.041 comp thick
Piston 5 thou in the hole
Colt custom ground cam 234@50(didnt come with a cam card and I haven't degreed it yet so I used Intake colsing point from this camhttp://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=190&sb=2
Edelbrock performer RPM heads (64cc)
Air Gap intake
750 double pumper
hooker long tube
Old 01-15-2013, 12:05 AM
I tried attaching the link for the cam I used to calculate DCR. It is a comp XR288HR. The duration is close so I used the closing point of the intake valve assuming it would be close.....but you know what they say about assumeing. I will be checking all of the timing events with a degree wheel.
Old 01-15-2013, 12:26 AM
vinniekq2's Avatar
Man that car is gonna scoot!measure the combustion chambers.what is the best fuel in your area?
Old 01-15-2013, 12:36 AM
They are advertised as a 64cc chamber but I've read sometimes they aren't bang on. I think there is a stations that sell 94 octane but I'm not 100% sure. We want to be able to run it on 91. Don't want to have to drive across town to put gas in it. Hey Vin. What do you think abot opening up the chambers a bit?? Or do you think we will be ok on 91. It will be extremely time consuming to grind and cc every chamber I would think.
Old 01-15-2013, 12:47 AM
vinniekq2's Avatar
after you get a chance to measure the heads,we can get the master tech to do some math.We need the cam specs too.The cam can be put in a couple degrees late if required.Im more concerned the heads were milled. I tune my car for 92 octane and my CR is 10.75
Old 01-15-2013, 12:59 AM
Thanks Vin. Sounds like a plan. Ill get a head cc'ed in the next day or 2. I aslo called the guy who ground the cam. He said there will be a part # on the back. I'm going to slide it out and get the part number. He said he would be more than happy to provide me with the specs.
Old 01-15-2013, 09:49 AM
10.94:1 is defiantly not idealfor what we want to do with the car .I'd rathher see it between 10-10.5:1 (ie 10.2:1). Fbird, what do you think about opening up the chambers 5cc's or so? If I used the texture from the casting as a guide and sanded evenlly across the chamber how many cc's wold I pick up?
I defianlty want to be able to run on 91 with no issue.
Old 01-15-2013, 11:22 AM
prostcelica,
Even though your post was directed to someone else, I thought I might chime in. I have spent alot of time with a set of RPM heads(70cc advertised) cc'ing, and trying to equalize the chambers. Unfortunately I didn't measure them before I started blending sharp edges around the seat inserts, and polishing to give you an idea how much of a difference it made. I know the polishing is just going to get covered with carbon, but from what I've read it will still help a little to reflect heat back into the chamber and avoid hot spots.
The point I was trying to share is that it takes a lot of grinding to make much of a difference. To gain 5cc equally on all chambers without compromising their integrity would take an extremly long time if even possible IMHO. You would have to remove alot of metal that might weaken them or hurt their combustion efficency, but JMO.
I believe you would be much better off buying another set of pistons with a 12cc "D" dish, but JMO.
I'm in process of building a 383 much like the one you described. 0.040 overbore, 5cc vr pistons, 4.166" x .039" gasket, and zero piston to deck height with 71.4-72.0 cc chambers. I get around 10.2-10.3:1 CR. I trying the groove thing for all the insurance I can get, even though I have no proof they work. Forgive the spelling.
FWIW,
ssmonty
ID:	70618   Click image for larger version
ID:	70619   Click image for larger version
Old 01-15-2013, 12:47 PM
Greg T's Avatar
www.krusinklassics.net
You may want to consider H2O/meth injection. For a few hundred you can run that compression and fuel without worry. I've used these in the past they work VERY well.
Old 01-15-2013, 01:16 PM
Why don't you just plan on using 94? There's at least 1 gas station near you that sells 94 (10% ethanol). Husky/Mohawk in town and possibly the one south of town near your brothers place. There may be others too. Pretty sure 10% ethanol is ok as long as the carb and fuel lines can handle it.
Old 01-15-2013, 01:34 PM
vinniekq2's Avatar
Try to use chevron 94 as it contains no ethanol. 10% ethanol will cost power
Old 01-15-2013, 01:36 PM
Yes, but will it cost as much power as lowering the compression to use 91?
Old 01-15-2013, 07:15 PM
So will 10.95:1 work well on 94 ?
Old 01-15-2013, 11:09 PM
I want to get the compression down. What about getting a little from everywhere. Run a couple thou thinker gasket, polish the chambers and pick up a cc or 2 and enlarge the valve reliefs slightly (I've heard of people doing this. Not sure if its a good idea)
Old 01-16-2013, 07:18 AM
Greg T's Avatar
You can do all that if you like and won't change much. I would just install a water injector and call it a day. If the motor is not built yet, change pistons.
how to run 383 stroker on pump gas 383elky Engine 27 08-23-2011 02:21 PM
Pump Gas Versus Race Gas / dyno results ?? fastlaners Engine 8 04-30-2011 11:51 PM
Is it normal to have to pump the gas several times to get accelerator pump squirt ? fumplet Engine 3 11-16-2010 02:14 PM
mixes marine gas and regular pump gas crussell85 Engine 3 08-20-2010 09:19 PM
mixes marine gas and regular pump gas crussell85 Engine 4 08-19-2010 07:30 AM
