383 question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2009, 10:46 PM
383 question
My dad is building a 383 chevy and I told him I knew just where to get some answers for him so here goes. I was told that 5.7 and 6.0 rods are not actually the same length as 350-400 rods. From what I understand the 400 rods are actually something like 5.65 not sure exactly but not six inch and that 350 rods are a little shorter than a 5.7 rod something like 5.4 or 5.5 but not exactly 5.7. Keep in mind we're trying to learn here and this info I'm saying could be wrong cause im not sure. But in order to use an actual 350 piston you would have to use real 400 rods. Which this is one of the big mysteries is are the 400 rods not the same as 6.0. The 400 crank is 3.75 right? If you use a 5.7 rod you would have to use and actual 383 piston which is different than a 350 piston? I do know that if you use a 6.0 rod the wristpin will be into the oil ring. Could someone give me each scenerio. I dont need any part numbers just what each of the 3 combos need to work that way my dad get busy building so we can have the father son shootout this spring, Pretty sure the boys big block will prevail so might have to let him win but I wont tell. One more thing, Is there truth in the 6.0 rod builds more torque than the 5.7. They both end being 383's. If this is true please explain this to. He will be using vortec heads 64cc and he has a dual quad high rise with 450 carbs will this go on the vortec heads? We know it wont just bolt on. What do you have to do to make it work? He'll be using 12cc dish pistons which I think should be around 10.25 What is a good lumpy cam? It will see the strip in an s-10 pickup with 3.50 gears, turbo 350 and 3000 stahl thanksI sure appreciate all of your help thanks guys!
Old 02-22-2009, 12:58 AM
DoubleVision's Avatar
All small block chevy engines in the 1st generation used 5.703 inch rods except the 400. The 400 used shorter 5.565 rods. The only difference is the journal sizes. From 1955 to 1967 they used "small journal" rods and from 1968 on they used "medium journal" rods. If you used 5.565 rods you could use 350 pistons. If you use 5.7 rods (which I certainly would) use 383 chevy pistons. If you used 6.0 rods you would need a custom compression height piston. If you use the 5.7 or 6.0 inch rod, some clearencing will be required as usually the rod will make contact with a cam lobe and we usually shoot for .050 clearence.
A 5.7 rod will require a 1.425 compression height piston.
A 6.0 rod will require a 1.125 compression height.
Old 02-22-2009, 09:20 AM
383 question's
If you use an aftermarket eagle crank does this still require you to clearance the block. Also is there truth to using the longer 6.0 inch rod builds more torque? I was told that if you use a 6.0 rod the it is tryibg to shove the piston through the side of the block and is a high stress point. I was trying to picture this and to me it would seem that the shorter 5-7 rod would create way more piston to rod angle than the 6.0 rod. What do you guys think, just trying to help my old man out, he says thanks everyone.
Last edited by ssonny34@yahoo.com; 02-22-2009 at 09:25 AM. Reason: forgot to ask for more info
Old 02-22-2009, 09:48 AM
383ram's Avatar
Last wiki edit: Wheelbase, track width, and differential measureme...
Last journal entry: Upper P/S bracket made
My machinest always likes to use a long rod. Now your talking just over a 1/4" actual difference between 5.7 and 6.0. Doest sound like alot but i can make for better rod ratio's. So use the longest rod you can afford to use--gennerally 6" rods aren;t to much more than 5.7".
In certian cases (mine for example), you need a super dished piston and can only use a 5.7 rod because the dish forces the pin lower in the piston thus having to use a shorter rod. Most people arent looking to lower the compression though like i am. I am doing it for use on 87 octane with just a carb, but also a a small supercharger in the future.
Old 02-22-2009, 10:02 AM
Banned
6" rods tend to consume more oil as the result of an inferior oil ring land (the pin goes through the bottom). Some people say taht this oil consumption is acceptable and run a 6" others use a 5.7" rod for this reason.
NOw this part is debatable, but most people agree that:
a shorter rod will give you more torque at lower RPM levels, but a longer one will give you more hp at higher RPM levels, it has to do with piston dwell and the speed of combustion. I like using GM powdered metal 5.7" rods because they are cheap and have been proven pretty durable. I would use a 6" rod if I got a good set for cheap, but the rod angle/oil consumtion issue isn't enough of an argument to make me spend more on rods when money would be better spent on a LOT of other things like better pistons, rings, cam, rockers, valve springs, valves, etc.
IMO cost will be your deciding factor- if you have a good set of 5.7" rods on hand just run those, if you have to buy new rods 6" and 5.7" are usually the same cost so get the 6" for the better rod angles and reduced rotating mass. Your rod size is usually not a limiting factor on a street engine, and by usually I mean I have NEVER seen a case where it was the biggest single limiting issue.
On to the intake... Matching a standard intake to Vortc heads is usually not a good idea because the ports need a lot of work to line up. you can redril them to bolt together but bolting together and working together are two different things. A new intake would probably be the best step, or keep the tunnel ram and get different heads.
Old 02-22-2009, 10:04 AM
383 question's
Thanks for the info guys, He's got the eagle 3.75 forged crank, really good 5.7 rods.
Vortec heads that he'll put bigger valves in-2.02.
He also has a dual quad tunnel ram with two 450 carbs.
Can he put this intake and carb setup on the vortec heads?
I know there is something about the vortec bolt pattern?
Also he will use 12cc dish piston, with the vortec heads this should make 10.25 and run on premium gas.
He wants a good strip street cam combo to fit this motor. It will see the strip on weekends. turbo-350, 3000 stahl, he wants a good ratty sound but no plug fowling and so on.
Any recomendations?
Old 02-22-2009, 10:23 AM
Banned
Any recomendations?
If he wants it to run well without a LOT of intake work then he needs to get a different intake with port locations set up for Vortec heads. Also, going to 2.02" valves really isn't needed. In fact if you just do the valves and no matching port work he'll loose power. I would instead suggest switching the exhausts to 1.6" and doing some clean up work on the heads. Also, solid roller valvetrains are getting cheaper, you can get a lot of power swapping up to one of those, just make sure your valve job on the heads is matched to the lift.
Old 02-22-2009, 10:27 AM
383 q's
My dad doesnt have alot of money to sink into heads and am pretty sure that matching the parts that we have to eachother is more imortant than just dumping 3000 dollars into a set of heads for what he wants to do with the engine. I was just asking about our combination and trying to get some other info and opinions. Im sure that this combo that he is going to use will without a doubt will push an s-10 pickup plenty fast.
Last edited by ssonny34@yahoo.com; 02-22-2009 at 10:29 AM. Reason: forgot to mention
Old 02-22-2009, 10:51 AM
Banned
if he's planning to do street driving with it the best intake will more than likely be a Performer RPM from edlebrock. It fits the bill 95% of the time. You can do what Fbird sugested to get a tunnel ram working well, but the RPM is ahrd to beat out of the box for $200. As to the head modifications I was speaking about, you're looking at a total cost of about $400, including tools, and sending it out for the valve job, but not including springs.
Old 02-22-2009, 11:32 AM
Thanks for the info, much appreciated.
We'll stay with the 383 because we already have the rotating assembly, just need a cam. He's an old school hotrodder and has quite a few sets a early camel humps so maybe he can use them, the intake will bolt up then. I know that you get better power from on e carb and single plane intake but the tunnel ram dual quad is cool and does perform fairly well so thanks for the info.
Old 02-22-2009, 12:31 PM
31fordcoupe's Avatar
Last journal entry: Gunked up 454 water jacket
F-bird,
Would dual Holley 650 spread bores work for this set up? I currently have 450's on my SBC tunnel ram project (still very early in the making) and was wondering if the 650's would be ok or would 600's be better? Also was curious if it is better to go with mechanical secondaries or vacuum secondaries. My build will be very similar except on a 327 with some worked over hump heads at max RPM around 8k. Thanks.
Brent
Old 02-22-2009, 04:42 PM
i ran 5.7 rods, my friend ran 5.565 rods, other than that we had the same basic engine... they ran within a tenth of each other, same mph...
Old 02-22-2009, 07:22 PM
Banned
Originally Posted by 31fordcoupe
F-bird,
Brent
spreadbores on a tunnelram? Can it work, sure a lot CAN work, however if you think of why a tunnelram works well then you'll quickly realize that you need a square bore for a tunnel ram to work properly. And camelhumps can be great street heads if treated well, but they ARE NOT FOR 8,000 RPM racing. not even close. If you're going to spend the 3 grand you're going to need for the valvetrain its silly to not spend atleast 2 on some decent heads. Also, 8,000 RPM and vacuum carbs aren't a common combination, considering the cam you'll need to make power at that level and that it won't idle below 2,000 RPM vacuum carbs are kind of a silly thing to even think about.
BTW stock rods won't live at 8,000 RPM either.
Old 02-22-2009, 08:41 PM
Hadn't planned on using stock rods (although I knew a guy than ran stock rods in his 289 Mustang to 8k every weekend and had no problems) but thanks for the input.
And I can guarantee you it won't cost me $3000 for the valve train just to get them to run right at 8k. We ran camel hump heads in SBC's all the time in high school back in the day and they were reving to 7500 until the cows came home. They made plenty of power and it didn't cost us anywhere near $3000 on the valve train (even by todays market) to get them there.
I'll defer to F-birds comments on camel hump heads with a tunnel ram earlier in this post:
"You can make a very good tunnel ram motor using the Camel back heads too.
Look at this build up for inspiration. The camel back heads will need a good bit of porting to get the air flow up."
Old 02-23-2009, 06:17 AM
Banned
As you can see by that post, power fell off WAY before 8,000 RPM. ANd that was a really well buiilt engine with really well done heads. And I agree that it was a good tunnel ram camelhump engine, however it was nothing like what you are describing.
Engines don't make power at 8,000 RPM simply because you want them to, or because you can rev it that high in first gear. You're going to need solid rollers, a custom billet cam, super pricey springs, new pushrods, shaft rockers, new light weight valves, high end retainers and locks, and that's not even talking about the dry sump oiling system you'll need. Along with a really well prepped forged crank, racing rods, forged light weight pistons, a proper ring pack, proper bearings, a aftermarket block...
I'm not saying its not possible to hit 8,000 RPM with an almost stock engine, but it will not come close to holding it for even 30 seconds, or a handful of passes.
you can shoot for the moon if you want, but when you're shooting with a pea shooter don't expect to hit it.
383 piston question softballnrd27 Engine 2 01-15-2009 10:36 AM
Heelllllllppppppp 383 stroker Question MCSEllis Engine 5 10-09-2006 06:42 PM
383 Stroker Question 66 chevy truck Engine 3 09-27-2006 02:48 PM
383 question skz4u Engine 6 02-07-2006 04:24 PM
383 tbi question help steve raymer Engine 2 11-09-2004 11:56 AM
