500HP AFR Headed Crate Engine
if I had the money to build one the way I wanted. I would build it in a 4 bolt main block, balance the rotating assembly with 6" rods. forged crank, forged slugs, H beams & all roller. AFR heads. I would shot for the 550 HP mark, 500 + pump gas friendly horse power would be bad *****. or buy the 500 HP crate engine.
scroll down this page to the ZZ383-500 500 HP 383 Engines
the link is by featured products http://www.sallee-chevrolet.com/frame.html?/ChevyBigBlockV8s/572.html
ZZ383-500 �383 Stroker� 500 HP @ 5,700 RPM, 491 FT/LBS @ 4,600 RPM, P/N SCZZ383500
Anniversary ZZ383-500A, P/N SCZZ38350TH
GILBERT CHEVROLET has a �New� 383 c.i.d. crate engine, the ZZ383-500, to add to our line up. The new ZZ383-500 puts out an impressive 500 hp @ 5,700 rpm and 491 ft/lbs. @ 4,600 rpm of torque. GILBERT CHEVROLET starts with the GM 383 short-block as the foundation for the ZZ383-500 and adds to it all the tried and proven components that combine to produce this engine. Keeping with the goal of making this engine useable for street and strip applications, we chose parts that were well suited to this application, like the hydraulic roller cam which has great idle, vacuum, and streetability characteristics. We added the AFR 6155 Rev. Kit to help the hydraulic lifters function effectively at high rpm.
The top end of the engine consist of a pair of special AFR 195cc cylinder heads and an Edelbrock Victor Jr. single plane intake manifold to help the engine breath throughout the rpm range set as the goal for this engine. The AFR heads have 58cc combustion chambers, which helps the ZZ383-500 attain a 10:1 compression ration, and the ZZ4 plug pattern. The Edelbrock intake manifold is good up to 8000 rpm which is more then adequate for the maximum rpm of 6,500 for this engine.
To finish off the ZZ383-500, we added the new Holley 0-82751 4150 Street Hp 750 cfm carburetor to keep up with the demands of this engine and the Proform 141-693 Chevrolet Clear Anodized Aircraft Aluminum Plain 14� air cleaner for its low profile, to aid in hood clearance, and the overall show quality appearance it give this engine.
At this time we do not have a base engine package put together for this engine, but if enough people express interest in one, we will be more then happy to put one together for everyone.
As part of the celebration of the GM small-block V8 50th anniversary, we made a special version of the ZZ383-500 called the ZZ383-500A which features special black power coat valve covers and the black painted Proform low profile air cleaner. You can read more about this and see pictures of this version on our page made specially for this. This version of the ZZ383-500 will only be produced for the year 2005.
ZZ383-500HP TECHNICAL INFORMATION
Parameter Specification
Horsepower: 500 @ 5,700 RPM
Torque: 491 @ 4,600 RPM
Max. Rec. RPM: 6,500 RPM
Comp. Ratio: 10.1:1
Partial Engine: GM P/N 12499106, 383ci
Block: P/N 88962516, Cast Iron, Four Bolt Main, 383 Stroke
Crankshaft: 12489436 Forged 4340 Steel
Connecting Rods: P/N 12497624 Stroker PM
Pistons: P/N 12499103 High Silicon .005 O/S
Piston Rings: 12499107 set .005 O/S
Camshaft: P/N 2204, Edelbrock Hyd. Roller, Lift (.539� I, .548� E), Duration @ .050� (234� I, 238� E)
Timing Chain: P/N 12371043, Single Roller Design
Timing Cover: P/N 12342089 GM, Chrome (Proform 141-215)
Timing Tab: P/N 12342011 GM, Chrome (Proform 141-202)
Lifters: P/N 875-16 �R� Series, Comp Cams Pro Magnum Hydraulic Roller.
Cylinder Heads: P/N 1038, Special AFR 195cc, 58cc combustion chamber
Cylinder Head Gasket: P/N 10105117 GM
Intake Valves: P/N 7204 AFR 2.020�
Exhaust Valves: P/N 7219 AFR 1.600�
Valve Springs: P/N 8020 AFR, Standard Hydraulic, 1.450� OD
Valve Spring Ret.: P/N 8510 AFR, Standard 10� 4140 Chrome Moly, 1.450� OD
Valve Seal: P/N 6611 AFR
Valve Spring Shims: P/N 8043 AFR, Hardened
Valve Lash: Hydraulic
Push Rods: P/N 25730 Manley
Rocker Arms: P/N 1301-16 Comp Cams or P/N 10750-16 Crane Cams (Your Choice)
Rev. Kit: P/N 6155 AFR (Page)
Spark Plugs: P/N 88901233 GM, Gap @ .035 For Points Distributor Or .045 For HEI Distributor
Intake Manifold: P/N 2975 Edelbrock Victor Jr., Port Matched To Heads
Intake Gasket: P/N 1205 Fel-Pro
Ignition Package: P/N 6420 MSD 6AL Box, P/N 8207 MSD Blaster Coil, P/N 85551 MSD Pro Billet Distributor
Ignition Timing: 12� BTDC @ 800 RPM, 36� total @ 3,200 RPM with vacuum advance line disconnected and plugged. This setting will produce 36� of total advance at wide open throttle (WOT).
Fuel: 92 Octane
Oil Pan: P/N 12557558 5 Quart Camaro/Caprice
Oil Pan Gasket: GM P/N 10108676
Oil Filter: PF1218
Oil Breather: P/N 141-616 Proform, Chrome
Oil Fill Cap: None, remove oil breather, for oil filling.
Valve Cover: P/N 12480127 GM, Bow Tie Cast Aluminum
Damper: P/N 12498008, Balanced 383 Stroker
Flex Plate: P/N 14088765, 153 Tooth
Water Pump: P/N 8810 Edelbrock, Short Style Or P/N 8811 Edelbrock, Long Style
Air Cleaner: P/N 141-693 Proform, Chevrolet Clear Anodized Aircraft Aluminum Plain 14�
(You can choice between any Proform air cleaner in exchange for 141-693 except 141-790.)
Carburetor: P/N 0-82751 Holley, 4150 Street HP, 750 CFM
Starter: P/N 10455709 GM, High Torque Gear Reduction
Starter Bolts: P/N 430-3505 ARP, ARP�300 100% Maintenance Free Stainless Steel.
Plug Wire/Loom Kit: Your Choice Of Either Listed Below:
GM Red 8 MM Wires (Performance or Bow Tie), Stainless Wire Looms
Moroso Blue Ultra 40 Wires, Moroso Wire Looms
