The cam to rod clearance is something you need to check real close. My machist told me about it when I picked up my motor, ready to be assembled. I didnt have any problems but he said if there was a clearance issue to just what your friend is doing. He does lots of high performance work around my area and has a super reputation. I think it is more to do with the centering of the cam in the block. they are all not exactly centered, and some need the rod caps ground a little and some dont.
Every block is different. I grind the inner rod bolt head on all 383 and 406 with 5.7 GM rods. Not much has to be removed. Easily done with a common bench grinder. Not all rods will hit. Usually one or two. Grinding all keeps the balance better.
if you run into this at assembly (with the rotating assembly already balanced) and then grind on rod cap bolts or rod caps does this throw it outa balance ? or not enough to worry about ?
just curious cause you spend the money to balance. Mustangsaly |
So if I use standard facotry rods with ARP bolts and a 383 crank with a standard base circle cam, can I make it fit with just a little grinding on the rod bolt caps?
ARP now makes special rod bolts for this application. The part number is 134-6027. They have a larger chamfer on the head for camshaft clearance. It's too late to use this info on your engine, but hopefully it will help others who are getting ready to build a 383.
Barry |
| stroke to rod ratio | jacobm99 | Engine | 17 | 09-16-2010 10:06 AM |
| Cam selection for Vortec Chevy 383 | mytruckownsit | Engine | 7 | 06-14-2006 07:16 AM |
| 383 Cam Choice Help plz | crusherdbuzz | Engine | 7 | 04-25-2006 04:15 PM |
| 383 stroker cam ? | 280zxWith305 | Engine | 10 | 04-10-2005 02:46 AM |
| longest rods in std deck 454 bbc?? | deuce_454 | Engine | 11 | 01-30-2004 10:06 AM |
