383 SBC Build advice - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-13-2011, 03:21 PM
Hi Guys and greeting from across the pond....
I'm building a manual trans'd mid engined VW with a 383 SBC I intend to build in the near future and wanted some advice regarding the build.
My target is to get to a 500/500 combo and from my research, there are a few dyno proven combos out there that will do this and retain some streetability.
My intended spec is...
383
ARF 195 heads
10.5 CR
Comp Cams Xtreme Energy 12-433-08
Forged Eagle Rods
Forged Eagle Crank
KB pistons
Edlebrock Perf RPM manifold
Edlebrock Thunder series 850 Carb
MSD etc, etc.
My concern is this....
For all sorts of reasons regarding UK legislation, emissions regulations, vehicle registration information etc, I'm pretty commited to using the block I have which is a L05 350 from a '1990 GMC Vandura.
I've taken it apart and can confirm the casting is a 10054727, 2 bolt mains and a non roller enabled block.
The two bolt mains isn't an issue as I can machine for splayed 4 bolt caps.
My area of concern is the fact that even though it is a post '87 block supplied with a flat tappet cam, like many of these truck and van motors from Canada, it does not have the casting provision for a roller cam....
I understand that at my target power figures, a roller cam is the preferred choice to retain any kind of street flexibility but I'm reading conflicting information about whether a roller cam can be installed in a non roller block?
Some people say there are kits available to do this on early (pre'87) blocks....? If this is the case, would the same kit work on a 1 piece rear seal '90 block?
Just need some guidance re getting a roller in the block I have. The block itself is a peachy, virginal, super nice low mileage example and as I say, I'm committed to using it.
Many thanks...
Andy
Old 10-13-2011, 04:17 PM
DoubleVision's Avatar
This is what "Retro Roller" Kits are for. They are offered by Comp Cams as well as other companies. When the blocks were changed to roller blocks in 1987 the passenger car line got rollers. Trucks got flat tappets. However, the flat tappet block didn`t change any from the pre 1987 days except for the switch from 2 piece rear main seals to 1 piece so the retro roller kit will work fine in your block.
Old 10-13-2011, 04:24 PM
That's fantastic news.....
Please may I ask a few questions regarding choice of components.
Given we are talking a manual trans and a 2600 lbs car which will get weekend blast + strip use, given my power targets, what would you recommend between...
Solid vrs Hydaulic lifters?
Edlebock RPM vrs Super Victor?
(Heads will be AFR Comps 195cc, fully forged crank, 6" rods, pistons)
Once again, many thanks.
Old 10-13-2011, 04:33 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Other than being somewhat expensive, ($695.00) you just need the correct size lifter with a support device, like the bar link, the same diameter, .0842". Some have better oiling qualities than others, grooved, etc. I've been running a solid Lunati roller cam with Isky RedZone Max Endurance (rebuildable) solid roller lifters, Summit p/n 272-RH, for several years in my blown small block, Gen I motor, no machining. I also run an Isky revkit, but it has nothing to do with the lifters or cam.
Crane and others make retrofit hydraulic rollers with the bar link, no machining required, if you go that way.
Sheesh, DV beat me on the draw...AGAIN. Just more warm and fuzzies for ya...
Semper Fi
Old 10-13-2011, 05:45 PM
For the record, here are some pictures taken 7 minutes ago of the block - as shown, it is a 1990, 1 piece main seal, none-roller block with no casting provision whatsoever for factory roller equipment.
So, just to confirm,there is such a thing as a post '87> retro fit kit which will be okay to use in this block despite there being no casting pads etc?
Thanks.... just want to be certain as the parts website are very ambiguous about what a retro kit will or won't fit in terms of +/- '87 or roller / non-roller block.
Nobody seems to acknowledge that there is such a thing as a post '87 non-roller block.
Old 10-13-2011, 06:25 PM
cool rockin daddy's Avatar
Yep! Use the search function and search for 383 builds. This has truly been beat to death.
a different 307 sbc build, need some advice v8fbrx7 Engine 97 07-25-2012 01:53 PM
350 build advice 75chev4x4 Hotrodding Basics 1 01-17-2011 12:54 PM
454 build need some advice 72olds Engine 17 09-24-2010 07:24 PM
406 sbc build need cam advice TCAMARO Engine 22 05-03-2005 01:26 PM
496 build up >>> NEED ADVICE terror385 Engine 5 11-17-2003 09:42 AM
