383 SBC cam swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2010, 04:37 PM
bowtietillidieSS's Avatar
383 SBC cam swap
i am considering swapping out the cam im running for something a little bit more mild, how difficult is it to change the cam with the engine still in the car? what does this job entail? please help!
Old 05-29-2010, 04:41 PM
Camaro_Nut2001's Avatar
Drag Racing Lover
Last journal entry: '68 Impala Project
Cam Swap
Depending on what car the engine is in you should be able to take the radiator and grill out and have enough room to swap them out.
Old 05-29-2010, 04:46 PM
383 sbc in 85 monte ss
Old 05-29-2010, 04:53 PM
also, any suggestions on cams? the guy i got the car from said its an isky cam with 525 lift and i believe it, has a nice lope, to much for everyday driving which i do in the car. it has smog heads 882 with 2.02 valves, i have a set of double humps for it just havent made the swap yet, th400 tranny with 2500 stall and 3.73 gears, looking for a good street cam this one is just to much for this build and nothing flows well. i have a weiand xcellerator intake or a holley street dominator. msd 6a box which i will be installing as soon as the harness' come in, HELP HELP HELP! not looking for 500 hp just a well meshed build. also have headers and 2.5 exhaust all the way back with flowmaster 40's
Old 05-29-2010, 05:56 PM
techinspector1's Avatar
Wiki Edits: 326
In order to intelligently choose a camshaft for a motor, you need to know the static compression ratio. You should also know the piston deck height. Yank the heads and measure how far down in the bore the piston is at TDC, that's the piston deck height. If you go shorter on the cam, you could run into some detonation problems if the static compression ratio does not match the cam profile. Probably not, with the 882 large chamber heads, but you never know how much they have been carved on before you got them. And you don't know what pistons are in the motor.
New SBC 383 build question + parts list Filmjay Engine 40 04-25-2010 09:25 PM
Help with cam selection on my 383 ags111075 Engine 1 10-08-2009 09:15 PM
Do oem 350 sbc roller cam's take the same cam bolts as older ones? eric32 Engine 5 04-20-2009 04:12 PM
383 chevy cam choice etc belairheaven Engine 3 02-10-2009 01:41 AM
Roller Cam worth the extra bucks for SBC 383 making like 400hp?? 89SDime Engine 10 03-11-2006 02:22 PM
