Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 383 SBC The ultimate stick
Old 01-07-2013, 01:10 AM
vinniekq2's Avatar
vinniekq2 vinniekq2 is online now
you could go a little smaller cam and use 1.6 rockers on the intake side. I said something like. I always wait until tech does the exact math.
want more torque play with the ICL,use FI,use a bullet spacer, change the booster venturi if you use a carb,check other intake manifolds, play with header primary length and diameter, use a 3.8 crank if you dont have a crank yet,
