383 SBC The ultimate stick - Page 6 - Hot Rod Forum : Hotrodders Bulletin Board
  #76 (permalink)
Old 09-03-2013, 09:51 PM
vinniekq2's Avatar
512 hp?
Originally Posted by bfritch View Post
I'm now looking into a 406 or 427 SBC short block, 10.3 and 10.0 compression (based on 64cc comb chamber), respectively. Will be using the same E-Tec 170cc heads and air gap intake. Super Chevy did a series called "Major Mouse" using a 427 cu in with 11:1 compression, same heads and intake and the cam an edelbrock 2201 cam 234/239 .539/.548 with 1.5 rockers but they used 1.6 rockers. The result was 512hp at 5400 rpm and 570tq at 4000, with more than 500 tq from 2500 to 5000 rpm. This is the type of power band I'm looking for. Would I be nuts to try for something similar with the 427 block? I was told the 170cc heads are just way too small for that many cubic inches, but look at those numbers. The article I mentioned was from the April 2005 issue of Super Chevy.
Thats a sad engine to build for a racey car.I would want a lot more than that,using bigger/better heads
What Is The Ultimate Street/Strip SBC Combo? (Updated) V8Guy427 Engine 5 04-04-2014 11:06 AM
Sbc 400. stick with powerglide or go T-350. savage9scorpio Transmission - Rearend 9 12-20-2012 06:04 PM
SBC 350 / SBC 383: Verification Tips and Methods lt1silverhawk Hotrodding Basics 8 06-17-2011 12:21 PM
383 chevy stick flywheel 65ELCMO Transmission - Rearend 5 03-18-2010 08:23 PM
SBC Dip Stick Sleeve Removal Houston54 Engine 4 09-26-2006 06:35 PM
