383 small block chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2012, 07:53 PM
im building a 383 sbc for my 85 Iroc camaro and was wondering if the tuneport setup off the 305 that was in it will fit and work on the 383?im hoping for 425HP(fingers crossed).the block is a 69-79 350 thats bored 30 over and its a 010/020 find.Any thoughts will be a big help, thanks Rob
Old 02-18-2012, 08:25 PM
DoubleVision's Avatar
You won't reach it with a stock tune port. It's airflow is Eqiv. to a 2 barrel carb as it was designed for mileage and low end torque.
Old 02-18-2012, 09:01 PM
383 sbc
how about if the throttle body is changed?
Old 02-18-2012, 09:54 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
It's going to take a lot more than a throttle body swap. The runners themselves aren't very big. There are aftermarket TPI runners and intake manifold bases that you can buy but I don't know if they will be able to get you there either.
Old 02-19-2012, 04:19 AM
383 sbc
ok thanks guys my original plan was to go carb but i didnt want to hack up the wiring since the car was F.I. so now i have to see if anyone makes a wiring harness that will plug right up to go carb.thanks again guys
Big block pil pump on small block Chevy dallam11 Engine 22 03-24-2012 07:36 PM
Can You I D a Block & Heads Small Block Chevy please? Rob Keller Engine 19 01-30-2011 08:39 AM
Big Block vs Small Block Chevy bigjoedo Engine 82 05-03-2010 03:36 PM
1986 305 chevy vs. 1987 305 chevy new style small block mtinsley Engine 2 08-22-2003 11:55 AM
55 chevy small block to big block ehchvac Engine 0 05-02-2002 08:23 PM
