Have a nice 383 stroker and my initial timing is sitting at 32 deg not total that is around 50.
I have check TDC using piston stop timing mark is maybe 1/8" off.
Using stock dist with printronix flame throwerII insert.
383 stroker
Edelbrock rpm performer heads
Edelbrock Performer manifold
Edelbrock 1406 600 CFM carb
Edelbrock Performer RPM Cam and Lifter Kits 7102
Rocker arms
Scat crank and rods
9.6:1 comp
Double roller chain set 6 on cam 12 on crank and 0 degs of advance.
When setting timing vac adv.is disconnected and plugged.
The last I checked when installing the dist on a sbc if it was at TDC on comp cyld 1 you had to make the contact point towards cylinder 1 (driver side front) and the vac canister on passenger side.
The engine fires pretty well but I think should fire faster.
Any Ideas or just accept due to the cam that the timing is not falling in spec (personally I do not buy this) I think something is wrong.
383 stroker
Rocker arms
Scat crank and rods
9.6:1 comp
