383 stoker need help - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 03-30-2013, 09:40 AM
matheny00's Avatar
Craig Matheny
Originally Posted by thinwhiteduke View Post
That hole in the front of the block near the fuel pump is there so you can screw a bolt in to touch and grab the fuel pump push rod to hold it up while for ease of installation of the pump. After, it should be plugged with a 'short' bolt to prevent oil leaking. Be sure you bolt is not too long and fouling on the rod. If your measuring from the shoulder of the bolt 1" is WAY to long! I'm surprised t didn't bottom out on the pump rod. The hole is only 3/4" deep!
Duke
Thanks I am using an electric pump so I have a block off plate so I am ok on clearance
If you do not want to register, fill this field only and the name will be used as user name for your post.
383 Stoker Timing pottsie454 Engine 10 12-05-2011 03:44 PM
Is it a 383 Stoker? Cole Engine 3 02-16-2010 07:28 AM
383 Stoker vs 383 Chrysler Jag Daddy Engine 100 08-14-2008 11:48 AM
383 stoker mt racer Engine 3 12-02-2007 09:09 PM
New 383 Stoker Motor Novastroker Engine 10 04-25-2003 04:48 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
