What are you asking for a crankshaft kit for a 383 cid? There is no crankshaft kit that turns a 350 cid into a 383 cid. You have to buy the crankshaft for a 383 cid and pistons for a 383 cid. The 350 pistons and the 383 pistons have different compression heights. You can use the rods from a 350 cid. This is why everyone buys a 383 rotating assembly. By the time you buy a crankshaft, pistons, rings, main bearings, and rod bearings separate it will cost almost as much as a rotating assembly. Here is an Eagle 3.750 stroke Chevy crankshaft for a 383 cid engine.
Eagle Cast Steel Crankshafts 103503750 - SummitRacing.com Here is the price of an Eagle 383 rotating assembly.
http://www.summitracing.com/parts/es...make/chevrolet
