383 strocker kit - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2013, 02:42 AM
383 strocker kit
what are the part numbers for a crank kit that will turn a 350 into a 383 strocker?
Old 01-06-2013, 05:35 AM
383 strocker kit
What are you asking for a crankshaft kit for a 383 cid? There is no crankshaft kit that turns a 350 cid into a 383 cid. You have to buy the crankshaft for a 383 cid and pistons for a 383 cid. The 350 pistons and the 383 pistons have different compression heights. You can use the rods from a 350 cid. This is why everyone buys a 383 rotating assembly. By the time you buy a crankshaft, pistons, rings, main bearings, and rod bearings separate it will cost almost as much as a rotating assembly. Here is an Eagle 3.750 stroke Chevy crankshaft for a 383 cid engine. Eagle Cast Steel Crankshafts 103503750 - SummitRacing.com Here is the price of an Eagle 383 rotating assembly. http://www.summitracing.com/parts/es...make/chevrolet
Old 01-06-2013, 02:26 PM
Old & Furious
I usally buy balamced rotating assembly.
Here is an ebay link for one kit that may work but you will need other to be sure its right for your engine.
Eagle SBC Stroker 350 383 Balanced Rotating Assembly | eBay
Old 01-06-2013, 02:49 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
The professional machine shop operators who are members of this site have warned us over and over not to trust the quality control of Eagle products. Purchase at your own risk. Measure all dimensions carefully before blindly installing Eagle products.
David Vizard, professional builder and author, tells us that the Scat cast steel crank and Scat Pro Stock rods are good for 550 hp. He has been using them for years and reports that dimensions are right on the money and that he has never fragged a Scat crank or rod. Combine Scat pieces with a good-quality forged piston such as SRP for a bulletproof reciprocating assembly up to 550 hp. Do you want to make 500 hp like everyone else? Start looking at Air Flow Research cylinder heads to use with your combination.
http://www.airflowresearch.com/chevy_dyno.php
The Following User Says Thank You to techinspector1 For This Useful Post:
1Gary (01-06-2013)
Old 01-07-2013, 01:21 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
This is a very broad question. To answer it will require some more info, like 1- or 2-piece rear main seal block, internal or external balance, 5.7" or 6" rods, cast or forged- or a combination, etc.
Old 01-07-2013, 05:41 AM
describe my 350 small block that i will be the basic for 383 strocker.The 350 is
MY 350 engine is a 2 piece rear main seal block,internal balanced,5.7 rods,and cast pistons. I have aleady BROUGHT a 83 crank.
Can I make a 383 strocker out of a 5.3 ltr penguinoitaliano Engine 5 01-25-2007 03:52 PM
350 to a 383 strocker 76 CAPRICE Hotrodding Basics 4 07-26-2004 09:43 AM
400 strocker bdsjj Engine 21 01-22-2004 04:55 PM
383 kit? nova33 Engine 2 10-10-2002 07:34 PM
