Hotrodders Bulletin Board > Tech Help> Engine
Register now (free) or login to remove ads
Thread Tools Search this Thread share on Facebook
  #1
Old 01-23-2008, 06:36 PM
JTO JTO is offline
383 stroker
I have a 383 stroker with 6in rod and .030 flattop piston 2 valve relief
they are ( speed pro #h124cl.) what would be a good head and cam to use this will be street use only and use pump gas.I don't have feel for head and cam to use concern about compression.
thanks
  #2
Old 01-23-2008, 08:07 PM
curtis73's Avatar
curtis73 curtis73 is offline
Hates liver, but loves Jmark
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
Vortecs with a touch of pocket porting will be great on the street. The 64cc chambers will put you at about 10.5 compression with an .039 felpro gasket, but the excellent chamber design will let you run high octane. Keep total advance in the 34 degree range.
For a cam, it would help if we knew the car and its weight. transmission? rear ratio? tire size?
Old 01-24-2008, 01:26 AM
Bigpumkin Bigpumkin is offline
wow---you really need all that to suggest a cam??
Old 01-24-2008, 03:26 AM
curtis73's Avatar
Wiki Edits: 16
Yup. You can't go stabbing a huge cam in an F350 that weighs 7000 lbs with 3.42 gears. It also means a lot if he's using a 700r4 with its 3.06 first gear or a T56 with a 2.66 first gear and .50 double overdrive.
its not necessary to know all that, but it really makes a huge difference between a well matched setup and a slug performer.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "383 stroker"
ThreadThread StarterForumRepliesLast Post
383 Stroker questionHouman SS '70Engine6010-30-2009 08:46 AM
383 Stroker QuestionthebellmanEngine302-01-2007 03:56 PM
383 stroker kit (Ebay)HazardEngine805-24-2006 07:51 AM
Thanks for the 383 Stroker infoRon MexicoIntroduce Yourself201-11-2006 12:05 PM
I need your feedback Specs for my new 383 strokerozztEngine1201-11-2006 11:12 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
