383 stroker - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2012, 05:12 PM
383 stroker
Building a 383 for my demo car just not sure what cam 2 use I don't want a
Thumpy cam but I want a lot of torque
Old 01-11-2012, 07:25 PM
A basic rule of thumb if you want torque is to use a higher lift, shorter duration cam.
The opposite is true if you want screaming high rpm's...longer duration, and a little less lift.
I realize this is simplifying it, but that's about how it works.
Old 01-12-2012, 02:34 PM
techinspector1's Avatar
Wiki Edits: 326
Tell us what parts you have or what parts you are planning to buy/swap/trade for. Auto or stick? What rear gear?
Old 01-12-2012, 04:43 PM
Oh it has dart heads off a buddy's race car eagle 6 inch H beam rods 30 over pistons edelbrock performer intake roller rockers auto tranny 456 gears
Old 01-12-2012, 05:39 PM
Wiki Edits: 326
Do you have any idea what the chamber size is?
How far down in the bore is the piston at TDC?
What thickness head gasket?
Describe the piston crown or give us the part number.
Old 01-12-2012, 05:53 PM
Not sure what the chamber size is and the motor is still in pieces
Old 01-12-2012, 06:18 PM
Wiki Edits: 326
Good, time to begin measuring.
383 stroker or 396 stroker crate engine augustine Hotrodding Basics 5 11-26-2011 11:12 AM
Stroker dale_gribble86 Engine 9 02-01-2006 09:18 PM
383 stroker????????? 84oldsbcs Engine 3 09-26-2005 12:19 PM
383 stroker waltnardo Engine 3 09-24-2005 11:30 PM
z stroker strokemyz Introduce Yourself 1 09-11-2005 08:22 AM
