383 stroker - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2012, 10:53 AM
383 stroker
i am building a 383 stroker out of a 95 block to go in a 4 wheel drive what size cam should i use
Old 01-31-2012, 12:46 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
One that fits...
Old 02-02-2012, 08:44 AM
I would decide which cam brand you wanted to use, then call their tech line for their recommendation. They will ask alot of info about the rest of the engine and also the vehicle and its intended use. They have spent the big dollars and time in R&D, and should be able to give you the choices of their product that will serve you best. I have talked to Comp several times and havent been disappointed. For your trk they will definitely steer you towards low to mid range torq. Good luck and happy mudding!
383 stroker or 396 stroker crate engine augustine Hotrodding Basics 5 11-26-2011 11:12 AM
454 stroker help vcb Engine 11 04-01-2010 01:40 PM
383 stroker anthony todero Engine 1 08-13-2008 08:14 PM
383 stroker???? redneckincamaro Introduce Yourself 1 10-03-2004 08:04 AM
