383 stroker - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2012, 12:53 PM
tko tko is offline
383 stroker
hey guys i am new for this thing and i am wondering if there is anyone out ther willing to help me ... OK hear is the thing i am trying to build 1978 corvette 383 strocker and i don't know what kind carburetor to good to use with my engine setup i 1) SCAT Rotating assembly, forged steel.
2) PBM connecting rods CR5701 SBC 5.7" I-beam
3) Heads- Early 90's corvette. Flows 235cc @ 6000rpm.
4) Comp cam- part # 12-450-8. Adv dur: 286/286. Dur @ .050 230/230. Lobe separation 110. Valve lift .560/.560
5) PowerForce harmonic damper
6) Crane Cams Rocker Arms part # 11744-16. Energizer rocker arms 1.5 ratio with 3/8" studs
7) Comp Cams CS Retro Hydrolic roller lifter adapter part #853-16
8) Comp Cams push rods part #7609-16. CS 7.3. 5/16"Magnum
9) Edelbrock high volume aluminum water pump. Part # EDL-8812
10) Edelbrock Intake Manifold part #7516. Performer RPM Air-Gap Vortec
11) MSD Pro-Billet distributor part #85551
12) MSD Ignition control. 6A part #6200
13) MSD High Performance Blaster Coil. Part # 8202
14) Hooker Headers- Ceramic side pipeshave
15) 700r4 transmission
***** and wanna know how much estimated hp would be with this specs
Old 03-21-2012, 05:49 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Why aren't you running the rods that come with the rotating assembly?
Old 03-21-2012, 06:13 PM
tko tko is offline
I bought it like that .....
Old 03-21-2012, 11:26 PM
cam might be too big for those heads but youll be alright. as far as carb goes, holley 4150 600cfm or 650cfm. 700s would be fine but over kill, them heads are probly 1.95s. my 73 vette has 2.02 heads with a .510 comp cam and i run a 650 holley 4150. the performance is perfect. great throttle response. i also run hooker side pipes and a air gap intake.
Old 03-21-2012, 11:32 PM
tko tko is offline
How much hp do you think will put out
Old 03-21-2012, 11:42 PM
prob around 400hp......but who cares bout horsepower!!! its TORQUE what you want brother. what will get you of that line. torque is all you need in the city, towing, or 1/4 mile strip. these companies are selling heads, cam etc. by telling you how much TOP END HORSEPOWER there giving. but what they dont tell you is that your torque will start at 35k rpm
Old 03-22-2012, 04:49 PM
my87Z's Avatar
Veteran/Firefighter-Paramedic
IMHO if you are spending that much money on a motor and all knew HP parts then why are you going with a set of heads that was put on a motor ment for 275hp. yes you could get some porting/valve work done to them, but even after you spent all that money on machine work you would still end up with a set of moderately performing heads. really the only time that porting a set of older heads is more benificial than buying a new set of heads is when you are porting them your self. you could spend about 1000.00 on a set of really decent DART 200cc platinum heads, or RHS ProAction heads, or if your budget allowed 1200.00 then go after a set of Brodix IK200 heads or DART Pro-1 heads. Yes they will cost more than rebuilding, porting, and doing valve work will (avg cost around 500-600) but i garrentee you that money will be well spent.
dont cheap out on your heads.
as far as a carb i would recomend a Holley 3310 750vac sec carb.
383 stroker or 396 stroker crate engine augustine Hotrodding Basics 5 11-26-2011 11:12 AM
496 Stroker oil pan chasinya Engine 3 08-07-2009 03:49 PM
383 stroker mattmar Engine 3 07-30-2009 12:14 AM
421 SB stroker dgcantrellsr Engine 7 11-23-2005 11:38 PM
383 Stroker Ozz1967 Engine 11 11-04-2005 06:08 AM
