383 stroker - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2012, 08:22 PM
383 stroker
hello everyone..im a new member but ive been reading post for some time now..i have a 76 chevy chopped top truck that ive been fixing up for a while now..its time for the power plant now..my question is about a 383 stroker with sportman 2 heads,scat crank,eagle 4130 i beam rods,30 over flat tops,580 lift cam,should i go with a 750 or 850 double pumper?..just curious what some of you guys think.this is my first horsepower engine,my kids are grown and can finally afford a little extras here and there..thanks for the help any advice is welcomed...
Old 07-13-2012, 09:39 PM
vinniekq2's Avatar
both carbs are good.I use a 950 on my 434.
Old 07-13-2012, 10:14 PM
i bought the engine and was told it made 560 horsepower..i dont believe it..ive not put in in the truck yet tho..kinda curious of what 383 strokers can make horsepower wise?different ratios i understand with different setups..
Old 07-14-2012, 09:12 AM
vinniekq2's Avatar
560 hp?
To make 1.5 ish hp per cubic inch of displacement you will need serious parts.Example: an LS-3 make about 1.25 HP/cubic inch with a hydraulic roller cam,good flowing heads,fuel injection and a very good intake manifold.Your 383 will need to better all of those parts likely including a solid roller cam to make 560 hp.
The cost of a gasket set will tell you exactly what you have.
383, chevy
383 stroker v.s. 383 chrysler ...the end mcharger440 Engine 58 12-07-2012 08:16 AM
383 stroker 1_bad_nova73 Hotrodding Basics 16 01-31-2012 01:13 PM
383 stroker Demo man Hotrodding Basics 6 01-12-2012 06:18 PM
383 stroker or 396 stroker crate engine augustine Hotrodding Basics 5 11-26-2011 11:12 AM
383 stroker youngsavage Engine 26 04-16-2010 01:51 PM
