383 Stroker - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2013, 12:12 AM
Nemeth's Avatar
My 327 Cruiser
383 Stroker
Hi guys, Im the new guy.I cant afford a dyno test but was wondering if any one could give me an educated guess my approx horse power.
Vortec Block bored 4.030
3.75 stroke one piece crank
Probe forged pistons
10.5 to 1 comp
Cam 236/242 @ .050 .544/.545 110 lsa Roller cam
Rhs Heads 180 cc intake 74 cc exhaust 202/ 1.6 valves
Crane 1.52 Rockers
Rpm Air Gap intake
670 Avenger
1 11/16 headman headers
MSD Ignition
Should I run a 750 Holley Mech Secondary?
Old 04-06-2013, 12:35 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
Aluminum RHS heads??.
Old 04-06-2013, 12:38 AM
Nemeth's Avatar
My 327 Cruiser
No Cast iron no detonation here
Old 04-06-2013, 12:42 AM
Nemeth's Avatar
My 327 Cruiser
Heads were milled to 59cc and block was decked to .010 have -12cc dished pistons running me 10.5 to 1 ish
Old 04-06-2013, 03:18 AM
vinniekq2's Avatar
440 hp at 5700 rpm,thats a guess.What do you think?
The Following User Says Thank You to vinniekq2 For This Useful Post:
Nemeth (04-07-2013)
Old 04-06-2013, 05:30 AM
1Gary's Avatar
Do think the 180cc intake runners are going to help you on the bottom/mid,but hold you back on the top end with a pretty sizable lift cam.Common place lift for a roller.
Not to second guess you,but heads with a intake runner in the range of 195 to 200cc would have moved the torque band up,but would bonus on the top end.
Your in the right ballpark with 335 duration(well close any-who)for 10.5 SCR wanting 333.
I'm not big on guessing games.More of a hard facts kind of guy.Torque wise I would think upper 4's is very doable.
The Following User Says Thank You to 1Gary For This Useful Post:
Nemeth (04-07-2013)
Old 04-07-2013, 12:44 AM
Nemeth's Avatar
My 327 Cruiser
Thanks for the input, this motor is spinning 6,000 RPM max, if I were doin 7 to 8 grand I would defiantly use bigger runners. I was hoping at least 425 horses
was reasonable...The other thing is Did I post incorrectly cause this post was moved from engine section
Old 04-07-2013, 12:47 AM
Nemeth's Avatar
My 327 Cruiser
How does the thanks thing work at the right of page???? Help thanks all
Old 04-07-2013, 12:54 AM
Nemeth's Avatar
My 327 Cruiser
Thank you for your input was hoping to get 425 horses out of it.
Old 04-07-2013, 01:03 AM
Nemeth's Avatar
My 327 Cruiser
Thank you for the input and was planning 6,000 Rpm motor when I built it. Cam is rated to 5,800 rpm and intake and heads will handle 6,200 Rpm Red line 6,500 so lower top end is ok. Was hoping build would be at least 425 horses. Thank you Again 1GARY.
Old 04-07-2013, 08:50 AM
vinniekq2's Avatar
cam Vs RPM
Cam manufacturers when printing information for catalogs for sbc usually use the 350 as a baseline.Your 383 will likely make the rated power a couple hundred RPM sooner.
Old 04-07-2013, 11:58 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Nemeth, if you click it, it leaves a thanks to that poster for his of her input. Kind of a nice perk for someone who the OP feels has helped in some way.
Semper Fi
The Following User Says Thank You to 68NovaSS For This Useful Post:
Crosley (04-07-2013)
Old 04-07-2013, 12:25 PM
vinniekq2's Avatar
head flow
your heads would work great on a 327 that revved past 7k,but a 383 would likely peak under 6k. The importance is that the parts match.You have more than enough heads to make 500HP,so Im sure your goal has been met.I like the conservative combo and look forward to a video.
I see your engine as one that will be very fun to drive in a street car.should spin the tires easily
Old 04-08-2013, 02:33 PM
techinspector1's Avatar
Wiki Edits: 326
Rule of thumb is vacuum secondaries with stock converter/auto. Mechanical secondaries if loose converter (~3000 stall) or manual trans.
Can run a dynosim for you is you furnish the following info....
Bore
Stroke
Rod Length
Cylinder head flow, intake and exhaust 0.100" through 0.700" or whatever the mfg or Stan Weiss site gives for range
Intake valve diameter
Exhaust valve diameter
Static compression ratio
CFM, type of induction (2-bbl, 4-bbl, TBI, TPI)
Intake manifold type, mfg (single 4-bbl, two 4-bbl, one 2-bbl, three 2-bbl, individual runner Weber, mechanical fuel injection, low-rise, high-rise, tunnel ram, dual-plane, single-plane, part no. if you have it.
Exhaust system (be specific, primary tube size if long-tube headers).
Camshaft
Part number, grind number.
Type (flat, roller, solid, hydraulic).
Intake valve lift, exhaust valve lift.
Timing info and at what tappet lift the info is valid, i.e. 0.006", 0.050", etc.
383 stroker v.s. 383 chrysler ...the end mcharger440 Engine 58 12-07-2012 09:16 AM
383 stroker Demo man Hotrodding Basics 6 01-12-2012 07:18 PM
383 stroker or 396 stroker crate engine augustine Hotrodding Basics 5 11-26-2011 12:12 PM
383 stroker... ourmartyr Engine 2 01-11-2008 08:18 AM
383 stroker???? redneckincamaro Introduce Yourself 1 10-03-2004 09:04 AM
