383 stroker - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-04-2004, 11:16 PM
383 stroker
to get a 383 stroker do u have to bore and stroke the engine or one or the other?
Old 01-04-2004, 11:48 PM
gt2betubbed's Avatar
Kid With A Wrench...
Last journal entry: The Blower and test fit.
both, to make a 383. If you don't bore it, it's like a 378 or something.
Old 01-04-2004, 11:50 PM
DoubleVision's Avatar
a 383 is a 350 block .030 over bored, and a 400 crankshaft with it`s main journals ground down to the 2.450 from 2.650. you can use the stock 5.565 400 rods and 350 pistons, although it`s recommended to use the 5.703 350 rods and custom pistons. you would also need the 400`s harmonic balancer and flexplate.
