Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 383 stroker or 355 build advice please
Old 02-25-2013, 05:19 PM
ap72 ap72 is offline
Banned
Originally Posted by vinniekq2 View Post
buy the heads first. the corvette engines from the late 80s were lame on a good day,ask me.
the heads will determine the entire build.That flat tappet cam is not going to get you to 400 hp
my 81 350 with manifold,modified 650 holley,actually flowing 780 cfm,1 5/8 headers,small comp cam.stock heads made 205 hp at the wheels.
Ive fixed that problem
That cam on a Vortec 350 has been proven MANY MANY times to end up in more than 400hp- flywheel though, not rear wheels.
And as noted HEADS are the most important part, as such I would not get those Edelbrock heads, for the same price look at some Jeg's or Summit house brand heads (Jegs are Profilers, Summits are Brodix).
If you don't have the carb you may want to get a bit bigger one, a 750cfm carb will have no problem.
