Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 383 stroker or 355 build advice please
Old 02-26-2013, 05:25 PM
vinniekq2's Avatar
vinniekq2 vinniekq2 is online now
roller cams
[QUOTE=Chad.;1650620]Yea that sounds close, lower compression 400 hp or so 383. I plan on using my 1980 L82 4 bolt main block with a Hydraulic Flat Tappet Camshaft though not a roller too pricey and would it even work with my block? I dont know[/QUOTE
I was introduced to my first roller cam in the 70s
since then I see no reason to use a flat tappet cam
