383 stroker or 396 stroker crate engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2011, 03:34 PM
I can buy this 383 crate stroker motor with Fast EZ EFI and with 430 HP/450 ft/lbs from Blueprint Engines for $5895( http://blueprintengines.com/index.ph...83-bp38313ctf1 ) OR I can buy this 396 stroker motor with carburetor with 485 HP/500 ft/lbs from Blueprint Engines for $5995 ( http://blueprintengines.com/index.php/gm-396-bp3961ctc )
I like the idea of the 396, but don't know how much better Fast EZ EFI is. Which is a better choice and compromise in the same price range?
How much better and happier will I be with Fast EZ EFI ?
I don't care about improved gas mileage, but increased throttle response would be great. If the motor comes dyno'd and I assumed tuned, is the Fast EZ EFI as important?
Old 11-25-2011, 05:10 PM
Landshark928's Avatar
FrankenPorsche
If it sees more street time, the EFI will be easier to live with. If it spends most of it's time at WOT, then the carb is fine. Better street manners or 50 more HP.
You can also get the 383 with a carb and save $1400...
http://www.jegs.com/i/Blueprint-Engi...ductId=1617608
Old 11-25-2011, 05:11 PM
Do your homework before buying a Blueprint engine!!
Old 11-25-2011, 06:57 PM
poncho62's Avatar
Wiki Edits: 5
What car is it going in?...the weight difference may be a factor to consider
Old 11-26-2011, 10:59 AM
1bad32's Avatar
I would agree!!
Old 11-26-2011, 12:12 PM
A 3300 LBS Bel Air.
383 sbc stroker engine duramax05 Engine 6 10-31-2011 10:59 PM
Blueprint 496 stroker crate engine?? what do you think? retrota79 Hotrodding Basics 22 06-21-2011 11:26 PM
Sallee Chevrolet’s ZZ450 383 Stroker Crate Engine TonyTheTiger Engine 2 09-10-2004 11:40 AM
Engine Stroker invincible Engine 4 08-16-2003 11:20 AM
383 stroker engine jimbob trucking on 2 Engine 5 09-02-2002 09:52 AM
