383 Stroker - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2002, 04:51 PM
Post 383 Stroker
Do 383 Strokers normally run hot on the street even if there pretty mild?
Old 11-27-2002, 05:04 PM
DoubleVision's Avatar
Post
They may run slightly hotter due to the increased stroke, but I`ve never known them to have any cooling problems that wasn`t related to elsewhere such as blown head gaskets or bad thermostat and etc. we ran one in the mud races years ago, it ran a constant 185-190 with 180 degree thermostat.
Old 11-27-2002, 05:08 PM
Post
What about a big block stroker motor? Say a 454 stroked-out? Would they runner any hotter or slightly hotter that a small block stroker would?
Old 11-27-2002, 05:47 PM
BOBCRMAN@aol.com's Avatar
Post
with the proper cooling system the stroked big block will not run any hotter than a stocker, its when you stsrt decreasing wall thickness by using massive (.100-.125")overbores that you start having heat problems. i ran big overbores on the street back in the seventies with a stock big block radiator and never had heat problems. but some others did usually from not using shrouds, improper spacing etc.
[ November 27, 2002: Message edited by: BOBCRMAN@aol.com ]</p>
