383 stroker - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2005, 07:17 PM
383 stroker
I've installed a 383 stroker in my 1983 Malibu wagon. I don't know how to set the timing. The cam that I have is a comp CS X4 254H - 11 which has a .447 intake & a .462 exhaust. Can anyone tell me what I should set the timing at?
Old 09-19-2005, 08:57 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Try an initial timing of 12 deg or so and go from there.
Old 09-24-2005, 06:46 PM
Blazin 72:
Thanks for the help I'll try that.
Old 09-24-2005, 11:30 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
ok You tell us nothing about your set up, only about your cam, and then somebody says 12*, so I guess you mean ignition timing not cam timing.
Nothing like guessing away 60 hp/torque. huh?
12* initial is a good starting place , considering your altitude and that we don't know anything about your set up.
centrifugal should start at 1000 rpm and come in about 24* at 3000 rpm, lower will probably be too aggressive.
vacuum should do about 12*, variable as per 60 mph cruise vacuum minus 2. recalibrate for highway load.
Cam timing should be cam company spec, dynamic cranking compression to maximum then advanced 2-4*.
Good luck, you need it.
383 Stroker question Houman SS '70 Engine 60 10-30-2009 07:46 AM
383 stroker kit (Ebay) Hazard Engine 8 05-24-2006 06:51 AM
I need your feedback Specs for my new 383 stroker ozzt Engine 12 01-11-2006 10:12 AM
need help selecting parts and help planning a chevrolet 383 stroker buildup goth_rod87 Engine 22 02-22-2005 02:40 PM
383 stroker markiemyster Engine 10 02-13-2004 06:36 AM
