383 stroker - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-08-2006, 09:52 PM
383 stroker
needed helptiming motor . I have fuel and fire.
Old 06-09-2006, 07:13 AM
Take out # 1 plug and bump over slowly , while holding finger over the plug hole , or stuff a ball of paper towel into hole (not all the way in the cylinder). When you feel pressure buildup or the paper is blown out, you are coming up on TDC #1 firing . Look at timing mark on balancer and make sure you have not rolled past it. If it is not up to TDC manually roll it up with ratchet & socket.
Or if you can easily take off valve cover and watch #1 intake valve open and close then roll timing mark up to 10-12 degrees before TDC.
Pull dist cap and make sure rotor button is lined up with the # 1 plug wire, should be close up enough to fire , then put a timing light on it.
Old 06-09-2006, 08:25 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Uh...This is the Body forum....Best to place your engine questions in the Engine forum...
383 Stroker question Houman SS '70 Engine 60 10-30-2009 07:46 AM
383 stroker kit (Ebay) Hazard Engine 8 05-24-2006 06:51 AM
Thanks for the 383 Stroker info Ron Mexico Introduce Yourself 2 01-11-2006 11:05 AM
I need your feedback Specs for my new 383 stroker ozzt Engine 12 01-11-2006 10:12 AM
383 Stroker kit on Ebay any good? sb72elcamino350 Engine 1 03-04-2004 08:02 PM
