Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 383 stroker assembly
Old 12-30-2012, 06:33 PM
Gus's 40 Gus's 40 is offline
Last journal entry: gus`s 40
the last couple I assembled I had to remove some material from top of the rod bolts to clear the cam, both blocks were lined bored, and one of them the bottom of the block where the oil pan goes needed a little room. I used plumbers putty on the rods and made sure I had at least .060 clearance
