Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 383 stroker assembly
Old 12-30-2012, 06:38 PM
377MONTE 377MONTE is offline
so obviously the cam needs to be installed during the mock up to check cam to rod clearance, but can the cam be installed without assembly lube? The lube would throw off my measurements, right? Also, do the bearings need to be lubed up or will they be fine dry since you are only turning the motor over by hand?
