383 stroker assembly - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-30-2012, 05:20 PM
Alright guys, all the pieces and parts have arrived and I am ready to start the mock up assembly of my 383 to make the required clearances. I need some advice on the details..
Can somebody please break down the steps of the mock up assembly in detail? I have the basics down, just want to make sure I have all the details down pat too.
Old 12-30-2012, 05:33 PM
Last journal entry: gus`s 40
the last couple I assembled I had to remove some material from top of the rod bolts to clear the cam, both blocks were lined bored, and one of them the bottom of the block where the oil pan goes needed a little room. I used plumbers putty on the rods and made sure I had at least .060 clearance
Old 12-30-2012, 05:38 PM
so obviously the cam needs to be installed during the mock up to check cam to rod clearance, but can the cam be installed without assembly lube? The lube would throw off my measurements, right? Also, do the bearings need to be lubed up or will they be fine dry since you are only turning the motor over by hand?
Old 12-30-2012, 05:39 PM
Is it alright to use the same bearings that I will be using in the finished product or do I need to find some throw away bearings to use for the mock up and cutting?
Old 12-31-2012, 06:32 AM
I use the same bearings its going to run and I do lube all the bearing surfaces, you will want to thoroughly clean everything, allot!!!
Old 12-31-2012, 07:30 AM
I have built several 383. Something to watch out for Is the cam lobes may clear the rod bolts During your mockup assembly but after degreeing in the cam the lobes may hit.( most commonly on number 5) be sure your cam is degreed where you want during your mockup so you dont get a nasty surprise during final assembly.
383 rotating assembly crossbolted Engine 10 01-27-2012 01:32 PM
383 stroker or 396 stroker crate engine augustine Hotrodding Basics 5 11-26-2011 11:12 AM
Help with 383 assembly, finding parts benshelton383 Hotrodding Basics 5 11-19-2010 01:23 PM
383 Stroker Rotating Assembly questions darefugee Engine 1 11-05-2009 03:23 PM
383 stroker assembly/variant to their suggestions 57NAPCO Engine 1 02-12-2005 11:23 PM
