383 Stroker with blow by PCV problem - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-30-2013, 07:55 PM
No
It did not detonate. I think I am going to try a breather source. After I check the valves and rings.
  #17 (permalink)
Old 03-30-2013, 09:36 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Check the valves and springs for what? What are you looking for in that area related to excessive blowby? Worn valve guides maybe??
Semper Fi
  #18 (permalink)
Old 04-01-2013, 07:05 AM
Ok, let's make this easy. install a PCV valve on driverside valve cover. Run vacuum hose to the large fitting on carburetor. Install a breather cap on passenger side valve cover. The PCV valve will pull fresh air into the engine thru the breather cap when pulling a vacuum. You can also use a breather cap that has a fitting for a hose to run to the Crankcase Ventilation Hose Connection under the Air Filter assembly. Most aftermarket Air Filter asemblies provide this fitting.
  #19 (permalink)
Old 04-01-2013, 07:25 AM
BigMo's Avatar
leak it down......you got ring/cylinder seal problems sounds like.......pvc....yeah, ONE hooked to the engine vac source, but ya gotta have an inlet too, so a breather on the opposite side works good. this allows fresh in, and blowby back into the intake to be burned......disconnect pvc, remove breather, start motor....wat happens? oil/vapor fumes? is there enough that alot of pressure can be felt when you put your over the open hole?
  #20 (permalink)
Old 04-06-2013, 11:35 PM
got blowby fixed
but blew a head gasket! Thanks for the help.
  #21 (permalink)
Old 04-06-2013, 11:42 PM
blwn31's Avatar
What heads are you running? If aftermarket aluminum, is it possible the intake rocker studs threads are getting oil sucked through them? Ask me how I know...
Keith
  #22 (permalink)
Old 04-07-2013, 02:30 AM
Nemeth's Avatar
My 327 Cruiser
Pcv Issues
You know I had the same problem. I used taller valve covers with much better baffles in them, with a breather on one side and PCV on the other. Problem solved.
The Following User Says Thank You to Nemeth For This Useful Post:
RUFF 73 C10 (04-07-2013)
  #23 (permalink)
Old 04-07-2013, 08:04 PM
Not too sure
I am taking it back to Phoenix and tearing it all down. I bought the motor and transmission in Fresno. Ran it around and now its time to take it down and see what I have. I will keep everyone updated and thanks for the help. Ii am looking at some new heads just in case. Brodix makes a decent set any others you all prefer that are under 1300 dollars?
  #24 (permalink)
Old 04-07-2013, 08:11 PM
vinniekq2's Avatar
choose the heads to match the power you need,not by price tag
The Following User Says Thank You to vinniekq2 For This Useful Post:
  #25 (permalink)
Old 04-07-2013, 08:15 PM
Keith how do you know?
  #26 (permalink)
Old 04-07-2013, 08:21 PM
vinniekq2's Avatar
there are a few ways to determine how much head flow you need.The most simple but not most accurate is take the CFM air flow on the intake side of the heads and double it,,,IE: if a set of heads flows 250 cfm it will support 500 plus HP.It doesnt mean you will have 500 hp,just that if you use the correct combination of matching parts then the engine has potential to generate 500 HP. The exhaust side of the heads ideally will flow 75% or more of the intake figures.
The Following 2 Users Say Thank You to vinniekq2 For This Useful Post:
69 widetrack (04-08-2013), RUFF 73 C10 (04-08-2013)
  #27 (permalink)
Old 04-08-2013, 03:09 AM
Faith - Respect - Trust
Thanks for the great information, not just for this post, but all of your post. I think I've learned more things about making an engine go fast and hold together in the last 6 months by reading your posts and a few others than I have in the previous 57 years when I was thinking I knew a fair amount.
Thanks Again Vinnie
Ray
  #28 (permalink)
Old 04-13-2013, 12:13 PM
So I tore it down
Found out I have some 60's fuelie heads old enough that the valve seats are not hardened. I guess it IS time to start shopping for some new heads. I am going to post fuelies with casting number for some number matching restorer. They are the 202 with the angle spark plugs.......very rare for 50 year old heads. Ha ha! Thanks for everyones help. I will post again when I am done re re re building the 383.
  #29 (permalink)
Old 04-14-2013, 10:50 PM
blwn31's Avatar
This is a rather drawn out story, but true, and expensive.......
On my blown 406, the block didn't come drilled for a dipstick. It's a Rodeck 350+ Aluminum block that came out of a sprint car. Rodeck wouldn't even drill it. I had/have a Milodon 7qt drag pad on the motor and was looking for a way to keep an eye on the oil qty. I figured I could run around for one season without, just change the oil a couple of times. Anyway, I decided to go from Pleasanton to Sacramento, only 100 or so miles to the Golden State Nationals. Mind you, I had driven it around Pleasanton quite a bit. Well, I got about 20 miles out of town and she started to rattle the lifters and the oil pressure started to drop. Shut the car off and wait about 30 seconds, I fire her up and away we would go. I got to Manteca which was about 30 additional miles. We had to stop 2 more times. Since I couldn't check the oil, I dumped two more quarts into the pan. We left my buddies house and headed to Sac. We had to stop more times. Now, the drive home, which should of taken 1.5 hours took 6! The next day, I drained the pan, only had 3.5 quarts of oil left out of 7 or 9 depending on how you look at it. The engine never smoked a lot, just a little haze if you were looking real hard. The next winter I freshened the motor and had the valley drilled like a normal SBC for the oil to drain back, and removed a screen that was plugged with epoxy on the drivers side by the rear main cap. I also installed a Steff's sight glass in the oil pan to monitor oil quantity, and had the pan powder coated. Put her back together with the same rings in the same cylinders in the same positions (only 500 miles on them), but with new bearings. I changed the oil at 100 miles and everything seemed good. The oil looked new. After changing the oil things got worse. It was using more oil than before. One night before the Good Guys West Coast Nationals. I was at my buddies house in Brentwood. We dicided to pull the blower, he had a boroscope from work, so we looked down the intake runners an they were soaked/pooled with oil. I had already rerouted the PCV and we felt this wasn't the problem. We then pulled an intake stud out and the threads were completely soaked with oil. The anti seize had been completely washed off the threads. We cleaned up all the intake rocker studs and re-installed them with black RTV. The massive oil issue solved. But, things were still not Kosher. Remember the oil pan powder coat? The pan had trapped glass beads which by now had worked themselves loose and almost destroyed the lower end. Rebuild No. 2, removed the "O" rings in the deck and changed over to Cometic head gaskets and new rings and bearings. Now, everything is *****en and she runs scary awesome. No more leakage!
Keith
The Following User Says Thank You to blwn31 For This Useful Post:
RUFF 73 C10 (05-25-2013)
  #30 (permalink)
Old 04-14-2013, 11:09 PM
vinniekq2's Avatar
blwn31,you can get a dipstick kit for your oil pan.or make one,weld a tube to the pan and measure your own dipstick.
blow by new 383 stroker AFR heads Tmouse Engine 7 04-28-2012 12:55 AM
383 Stroker Starter Mesh Problem Answers larryf Engine 3 11-17-2010 06:16 PM
347 stroker with 6-71, blow's crankshaft seal's rojam18801 Engine 11 11-22-2009 04:27 PM
Ignition problem 383 stroker. pittbull7934 Engine 3 09-21-2009 01:08 AM
383 Chevy Stroker Valve Train Problem acav383stroker Engine 3 04-09-2009 12:27 PM
