383 Stroker Build. Got a Question? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2014, 05:28 PM
Im building a 383 stroker for my 79 Malibu. I am just building a decent power street motor for this car.
I will be using a Comp Cam 502 lift xtreme energy cam with Brodix 64cc heads. I will be using Forged mahle flat top pistons. Should be between 400 to 425 hp depending on a few touches here and there.
The questions is, for the crank and rods, I will be using Scat crank and rods, I am thinking just cast crank and rods will work, but looking for input if I should go with forged crank and rods? Which one? Cast or Forged crank and rods?
Thanks guys.
Old 01-22-2014, 06:02 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I've always been an overkill guy, and would go forged for the 425 hp range, but it's not necessary. I figure you're c.r. will be 11:1 if you're .025 in the hole, 11.7 if zero decked, assuming a .041 gasket, on the edge for pump gas. Also, depending on cam, intake, head specs and carb choice, 425 might be a stretch, more info needed to determine that.
Semper Fi
Old 01-22-2014, 06:08 PM
Well, Im asking about cast vs. forged parts right now. Im not concerned with listing all specs of the cam, intake, and heads and what not. Im building a motor between 400 to 425 hp. My question is, are forged parts necessary or not for a 400 to 425 hp street engine that is not turning high RPM's? Compression will stay around 11:1.
Old 01-22-2014, 06:15 PM
spinn's Avatar
Yeah, cast crank is fine for 400hp, its fine for 450.
Get your rods peened at least. It makes them awesome.
Old 01-22-2014, 06:46 PM
techinspector1's Avatar
Wiki Edits: 326
Scat cast steel crank, Scat Pro Stock forged steel rods. Good to 550 hp.
Street motor.....11:1 SCR......
Old 01-22-2014, 08:47 PM
The Scat Procomp rods with 7/16 bolts.
Make sure your using a stroker rods so you won't have to use a reduced base circle cam.
Old 01-22-2014, 11:12 PM
vinniekq2's Avatar
for a mere 425 hp,just build a 355
Old 01-23-2014, 11:12 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
Hoping your talking about a L31 roller block.Huge fan of Howards stroker kits but not just their forged crank but the full stroker kits and have them balanced.They come with 6" rods.
Competition Products - Performance Engine Parts, Racing Engine Parts and Accessories
If your talking about a 1pc rms block or crank,there is a adapter kit for that either way.
This adapter converts a 2pc rms crank to a 1pc rms block.
Nice thing about the Howards forged stuff is if you decide to hit it with spray,it gives you plenty of room to do that.
Old 01-25-2014, 10:47 PM
SPEED MASTERS CC's Avatar
Scat cast 9000 crank, Scat 6 inch, i beam, 7/16 cap screw type connecting rods, Mahle flat tops. = tough bottom end with 11-1 comp. Use E85 fuel or plan on mixing race and pump gas 50/50.
383 stroker build Q's greenmoonshine Engine 20 07-31-2010 05:19 AM
i need ur help to build a 383 stroker hoss15401 Introduce Yourself 2 10-14-2007 07:30 AM
How do I build a 383 stroker? KFXrider88 Engine 2 06-16-2006 01:10 PM
How to build a 383 stroker JAKE 68 GMC Engine 15 05-30-2006 02:28 PM
build a 383 stroker jo5hi3 Engine 4 11-20-2003 01:07 AM
