383 Stroker build questions - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-18-2010, 03:02 PM
55effie's Avatar
Wow, there oughta be a section on this forum JUST for 383 questions and topics. I just went through about twelve pages and there must be two threads per page about 383s.
So, After doing a little research I realize that superchargers are an animal all on their own. Is a Twin Screw the same as a Roots SC? And why is the 3 lobe rotor style called "Roots"?
It does not seem like a Roots type blower would have a very low thermal efficiency as some other types.
  #17 (permalink)
Old 09-18-2010, 06:00 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Faintly similar in that there are two rotors in each, driven mechanically off the crankshaft.
The twin screw, also known as the Lysholm screw, was concocted some 75 years ago by a Swede named Alf Lysholm. Being more efficient than the Roots-type, most of the large air compressors you see on the street being used on construction (or destruction) jobs are Lysholm screws.
Here is just one of many google entries explaining the blower...
http://www.custom-car.us/superchargers/twin-screw.aspx
The Roots blower was invented by the Roots brothers, Philander and Francis, about 155 years ago. Scroll down here for an interesting storyline....
There are many stories about the first uses of the Roots blower. The one I like best is that it was used to blow fresh air down into mine shafts to keep the miners aspirated.
http://www.dresserroots.com/document...0508_broch.pdf
You can see by the storyline above that the 3-lobe was introduced in 1914. The original 2-lobe was introduced in 1854.
There are certainly blowers out there with a higher efficiency. The Roots beats the air unmercifully. I haven't seen an efficiency graph, but would suspect the centrifugal to be the most efficient.
  #18 (permalink)
Old 09-21-2010, 11:05 PM
55effie's Avatar
Centrifugal is the most thermal efficient according to that web-page you posted, however it produces the least amount of boost at low RPM. Thus, application seems to necessitate the type of blower one desires. Hard to believe that technology that once supported breathable air for miners is now used for recreation in automobiles.
383 stroker built...now need cam suggestions Astrodokk Engine 8 01-31-2009 02:53 PM
383 stroker build 84berlinetta Engine 3 12-01-2008 06:48 PM
How to build a 383 stroker JAKE 68 GMC Engine 15 05-30-2006 01:28 PM
383 Stroker questions Pre-StrokerC1500 Engine 9 05-23-2006 01:53 PM
I want to build a 383 stroker and i don't know how...need info stud_duck77 Hotrodders' Lounge 5 05-23-2004 04:19 AM
