Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 383 stroker built...now need cam suggestions
Old 01-29-2009, 02:33 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
this cam may need to be ordered on a small base circle for stroker clearance
Will need a valve spring swap. Call Crane Cams directly for advice.
Another good choice is GM's "LT4 Hot Cam" GM #24502586 Best with 1.6 rockers. Stroker rod/cam lobe clearance needs to be checked before fireup.
The BFG tires are really going to hold you back on the strip.
Get some drag radials.
