If the Edelbrock performer rpm hyd roller performs anything like the regular hydraulic,I would recommend it.I would try to find a Z-28 high rise 67-69 instead of the Edelbrock.I think it would look and perform better.
this cam may need to be ordered on a small base circle for stroker clearance
Will need a valve spring swap. Call Crane Cams directly for advice. Another good choice is GM's "LT4 Hot Cam" GM #24502586 Best with 1.6 rockers. Stroker rod/cam lobe clearance needs to be checked before fireup. The BFG tires are really going to hold you back on the strip. Get some drag radials. Last edited by F-BIRD'88; 01-29-2009 at 02:42 PM. |
hi guys, give dokk a welcome, i recommended him to this websight.
our 2 cars are strikingly similar, both are coupes, 4 speed, 4.11 rear, flared fender cars with hooker headers and sidepipes. about the only difference is his is a 65 whereas mine is a 64, ( and his is in one peice less engine, and mine is in about 10,00 pieces- i'm doing a body off resto- )i told him to give as much info on the build as he can, and not just ask one of those "i have a chevy engine, what's the best cam? questions that always pop up" he is too intelligent to do that anyway. this is his first engine build, he is useing good quality parts but trying to maintain a budget and not break the bank. he is now at the cam choice part of his build and i think he is a little overwhelmed by the number of cam choices out there. hive him a hand--> OH, and HI ASTRODOKK
F-Bird'88, thanks for the link to that Crane cam card. The lift is at about what we're looking for and the duration is right on too. Since we're using end caps rather than nuts and bolts, there shouldn't be a clearace issue...but definitely will check.
Been looking at Isky and Comp cams too. I had a Crane Fireball 286 in my old 350 and it was nice! I had actually printed a cam spec sheet with these exact durations (from your link) at .050" but the lift was just a little more (518/239 vs your 509/528). So all the other info about spring loading and duration at .004" is different and that's where I get lost in deciphering that data. That's why I ask you pros! Thanks again. Carlos |
I used a Comp XR282HR in my 383 with 6" capscrew rods (I-beams) and I still had to clearance a few of them. (I did all of them, although only 3 gave me trouble) Don't take it for granted, check it.
Thanks Greg, I definitley will check all of them. Comp Cam XR282HR is a retrofit for the Gen 1 ver. 1 of the old 350 blocks. I have the Gen 1 ver. 2 ('88-up) with the factory roller cam and lifters, so I need the thrust plate type cam.
Thats what I have, the late model factory roller setup, that part is just the generic grind number, I think they even use it across all engine brands for the extreme energy hydraulic roller seires with 230/236 duration. 8-432-8 is the part number for the roller block version. I have it in my boat, idles strong at 950 or so with a 750DP carb, with a 650DP I can't get it to idle below 1000 for some reason, has about 10 inches of vacuum, but the signal is pretty strong and it doesn't drift around much. In a car I think I'd want about 22-2500 stall converter if I was running an auto trans.
| 383 cam | backyard71nova | Engine | 11 | 08-03-2009 06:07 PM |
| best cam for a 383 stroker??? need help choosing | 1BAD68 | Engine | 4 | 11-17-2008 03:50 PM |
| 383 Rod & Cam clearance | crusherdbuzz | Engine | 9 | 11-12-2006 06:17 PM |
| 383 stroker assembly/variant to their suggestions | 57NAPCO | Engine | 1 | 02-12-2005 11:23 PM |
| need cam suggestions for my 383 build | TCAMARO | Engine | 10 | 12-23-2004 04:51 PM |
