383 Stroker Cam Suggestions - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-01-2010, 02:08 PM
383 Stroker
Heads 2.02 1.6
Cam: 510/510, 244-244, 108
Holley 750dp
373 Gears
11:5.1 Cr
Looking For A Really Really Lopey Sound Like The Engines Is Gonna Jump Out Of The Car Will This Cam Do It For Me And What Would You Compare It Too
Old 10-01-2010, 02:32 PM
Originally Posted by mr_lwhite
383 Stroker
Heads 2.02 1.6
Holley 750dp
373 Gears
11:5.1 Cr
you need more detail and I hope you don't plan on trying to run pump gas.
Old 10-01-2010, 03:53 PM
what other info do you need??
Old 10-01-2010, 04:07 PM
Greg T's Avatar
www.krusinklassics.net
Head flow numbers or casting numbers would be nice. Also deck height, head gasket thickness, pistons, vehicle weight, gearing, etc.
Old 10-01-2010, 04:29 PM
Don't need any of that.
Exhaust set up and cam are most important.
Old 10-01-2010, 06:40 PM
Whats your guess on cam sound will it be what im looking for a really lopey cam like the engine is gonna jump out of the car??
Old 10-01-2010, 06:58 PM
Landshark928's Avatar
FrankenPorsche
Should have some lope to it. The more overlap and smaller the separation angle the more lope, generally. Then idle rpms has a lot to do with the sound.
If you drop the idle down it will seem to have more lope. However if you go to low it's a ***** to tune fore good acceleration.
If your cam is 244/244 @ 0.050" you're good. If it's advertised duration, your low.
If you give more info as to which heads you have, intake, roller cam? Solid or Hydraulic etc.. Someone will let you know if the overall set up makes sense. Killer idle lope followed by detonation at high RPMs will be short lived fun. You'll get chicks, but only in your driveway.
Old 10-01-2010, 07:05 PM
ericnova72's Avatar
More for Less Racer
Nope, not even close. Add 15 duration at .050" to those numbers, or reduce lobe seperation to 102-104.
If all you want is sound, go buy one of those Big Mutha Thumpr's, they are made for guys who value sound over actual performance.
Old 10-01-2010, 07:08 PM
i believe there dart iron eagle platinum series heads
244-244 @50
CAM:
Hydraulic camshaft, 3000-6500 RPM Range, 318 intake/318 exhaust Adv Dur, @.050 244 intake/244 exhaust, Valve Lift .510 intake/.510 exhaust, Lobe C/L 108.
Old 10-01-2010, 07:18 PM
FrankenPorsche
Is this the sound you want? Lunati Voodoo 60132 on 383.
VooDoo Video
Old 10-01-2010, 07:25 PM
thats the sound im looking for
Old 10-01-2010, 07:28 PM
FrankenPorsche
Lunati Voodoo 60105 should get you close if you want Hydralic flat tappet.
If can go roller the 60132 and flowmasters will give you pretty much the same sound he has.
Both cams will like the 11.5:1 compression and would be decent with the Iron Eagle Platinum heads. What intake do you have? Forged bottom and pistons or Hyper?
Old 10-01-2010, 07:36 PM
Greg T's Avatar
Yeah, just stick a huge bump stick in there and call it good. That'll work.
Old 10-01-2010, 07:38 PM
hyper. pistons and edelbrock rpm air gap intake
Old 10-01-2010, 07:47 PM
So the cam i have now will Not give me the sound im looking for??
The Following User Says Thank You to mr_lwhite For This Useful Post:
Brandon H. (04-30-2014)
383 Chevy Stroker Rod Clearancing Question 87iroc Engine 6 11-23-2009 07:52 AM
Help finding the right heads for my 383 stroker pittbull7934 Engine 33 07-08-2009 12:11 AM
best cam for a 383 stroker? 1BAD68 Engine 4 11-17-2008 04:50 PM
383 Rod & Cam clearance crusherdbuzz Engine 9 11-12-2006 07:17 PM
383 Cam Suggestions syborg3D Engine 19 07-17-2005 04:58 PM
