383 stroker...Done! Trans bad 4l60E:-( - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2011, 03:13 PM
I just took my conversion van to have the exhaust connected so I can drive it around until I get the proper exhaust system installed and had a problem. I got the van to the shop and they tried to pull it on to their lift (alignment rack style) but it wouldn't go. I knew it had some sloppy shifts when I drove it up there but I thought it was the computer needing to relearn. So now I need a 4l60E trans!!! Sucks!!!! I was looking at the monster trans. seems to be priced ok and if I get their converter it come with a 3 year warranty. Anyone have any other recommendations? I would like a trans that is beefed up enough to handle pulling a boat if needed or just to pull that heavy *** van around on it's own.
Old 09-28-2011, 05:04 PM
No one has any good info on where to get A nicely built 4l60E?
4L60e trans.problem bowtieguy45 Transmission - Rearend 3 02-26-2011 06:14 PM
4l60e trans or not? Scottsdale Transmission - Rearend 7 02-15-2011 04:36 PM
4l60e Trans. GMCTRUCKS Transmission - Rearend 11 10-21-2007 01:39 PM
4L60E Trans Swap MI2600 Transmission - Rearend 3 07-12-2003 11:36 PM
4l60e trans. r50max Transmission - Rearend 0 12-12-2002 01:14 PM
