I'm am in the process of dropping a 383 stoker
engine in my 1993 GMC truck.I wanted to stay with the fuel injection system,plus computor system and all the little goodies,such as remote start etc. But I've been told I would have less problems if I went to a carburator system.Can anyone give me some advise? |
Your computer will compensate for the increased cubic inches by itself. We have put 350's in place of 305's and 383's in place of 350's many many times and never had a problem.
If your fuel injection works ok now - it will work fine after the change. Thanks, Ron <a href="http://www.virtualengine2000.com/VirtualEngineCalculatorTour" target="_blank">Download Free Engine Math Calculator</a>
Absolutely not ! The injector size AND engine size have to be programmed correctly for the system to work on any fuel injected vehicles. There is no such thing as compensation for these things-the only exception to this is mass air flow vehicles, and the injector size is still necessary, if changed from stock. What needs to be know is that the tbi systems will not tolerate any sort of rough idle, and that if you intend on continuing to use the 4L60E transmission, which is wholly electronically controlled, then the factory system is necessary. Please discontinue spreading misinformation to other people, based on a lack of any information and knowledge on your part !!
I am not interested in getting into a flame war, but all I can say is I have done it many times and never had problems. Maybe if you are looking for the extra .2 miles per gallon or 1/10th second et, then maybe... it is worth all the extra changes.
[ January 25, 2002: Message edited by: RHamm1320 ]</p> |
You got half lucky on yours. Likely, your engine vacuum is just enough globally lower for your 383 to run smoothly, but 10 years of programming factory efi systems successfully will beat out dumb luck anyday. My only issue with you is that you should not spread misinformation, based on dumb luck, at best. Tell me what you know about comouter programming on efi vehicles.
