Cole |
I personally am not a proponent of this, preferring instead to dump the oil and filter after initial cam break in, then refill w/oil (and nowadays another dose of break in lube like ZDDPlus). This stays in the engine until 500 miles, then the oil and filter is changed again and from this point on, regular oil changes follow. But that's because that is how I was taught and it's worked well for me so many times. Just the same, I thought I'd throw it out there for your consideration/research. |
It's a gimmie! Drain the oil, pour in 7 qt's and filter, then check and mark your dipstick. No need to pull the pan. I wouldn't expect an engine broke in till about 300 mi with speeds 40-60 mph at operating temp. your engine defiantly needs more than 0* timing initial. I was shocked that it runs even half way decent at that setting.
You might want to check into a vacuum can resivor. With the big cam your not going to get the vacuum you need to operate the power brakes more than a couple pumps especialy with an auto trans and even with a manual. Last edited by sqzbox; 03-19-2011 at 11:21 AM. |
Hey guys, I finally got the oil changed. Put in a wick filter and Gibbs BR-30w in. I'm trying to work on the timing but can't get the thing to turn over now, I'll spend some more time on it tomorrow but kinda stumped as to what changed aside from the oil. Anyways I'll post tomorrow if I can get it going again.
| Valve Cover breather ??? | tubbedz | General Rodding Tech | 6 | 04-10-2009 06:50 AM |
| Ford, oil from valve cover to breather prob | DaSouthWon | Engine | 7 | 03-18-2008 10:57 AM |
| My Mavirick has white goo in my valve cover breather | Mr. Wormy | Engine | 5 | 02-09-2006 04:29 PM |
| Valve cover baffle and breather question | Jag Daddy | Engine | 4 | 03-19-2004 03:29 PM |
| Oil pumping out of valve cover breather? | Bad Ass Chevy | Engine | 11 | 05-25-2003 10:39 PM |
