383 Stroker Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2009, 12:08 AM
383 Stroker Help
Hello,
I am trying to build a 383 stroker and need some advice on cam selection. I got a pair of Patriot Performance SB-Chevy 225CC Freedom Series Heads with 64cc chambers. I plan on using roller rockers and a hydraulic flat tappet cam but cannot find anything on what i should use. I have 383 kit already with -12cc flat top pistons. they clame to have a compression ratio of 9.9:1. If anyone could help that would be greatly appreciated.
thanks
Old 10-15-2009, 07:18 AM
Big Mouse's Avatar
Stroked Z28
Welcome!
What is the application (% street vs. % strip)? What car, intake, trans, and gears?
You really need to do the math for your static compression ratio based upon your final bore, stroke, deck height, head gasket, pistons, and heads. You don't want to be guessing here. Google "static compression ratio calculator" and plug away.
Post back with these key details & you'll get some help.
383 stroker v.s. 383 chrysler ...the end mcharger440 Engine 58 12-07-2012 08:16 AM
383 Stroker question Houman SS '70 Engine 60 10-30-2009 07:46 AM
383 stroker built...now need cam suggestions Astrodokk Engine 7 01-31-2009 02:53 PM
383 Stroker Question thebellman Engine 3 02-01-2007 02:56 PM
I need your feedback Specs for my new 383 stroker ozzt Engine 12 01-11-2006 10:12 AM
